EMJunkie
Quote from: Jeg on January 23, 2015, 03:47:44 AM
Hi guys
On a tv Yoke i winded two partnered coils of 150 turns (approximately).
Input 12 turns, 24V/2A mosfet switching. At one side, the two halfs of the Yoke were insulated with tape. Trigger coil winded just over one of the two output coils.
When i shortcut the output, there is a small increment of the input current in the order of some 50-100mA. I guess that my partnered coils ended up with different overall turns in a degree that is enough to make this small increment.
I wonder if it will be any different reaction if i will take my output from an other 4th coil other than the partner coils. Will see. As i see it, to take out something useful, as EmJunkie said the partner coils have to add their E-fields. Or else the output will be a very low voltage one incapable for driving big loads.
EMJunkie what is your opinion if output is to be taken from the connection points of both the partnered coils? I mean, if partnered coils are not an open end ones, but instead to be connected between each other and taking the output from both connected ends?
ps. interesting results sky watcher. Well done! At your arrangement, is trigger coil in the middle or at the side of your core?
regards
@Jeg,
Can you please post a quick Picture? Close up of the coils?
Try moving the Partnered Output Coil Inter-Connections - See Pic:
Where A connects to B - Other terminals are your output terminals.
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
EMJunkie
Quote from: TinselKoala on January 23, 2015, 04:02:11 AM
More claims without the least trace of evidence. We've seen such claims before, and none of them have turned out to be true. The overwhelming probability is that these claims are also not true. Go ahead, PROVE ME WRONG by showing proper data. You won't do it... because you cannot. Anyone who actually could, would be happy to do so on this OPEN SOURCE forum.
@TinselKoala,
Why would you respond like this?
Check your PM's
Hurry up about it, I don't have all night!
Kind Regards
Jeg
Tinsel, i trust your judgment, but we have tried many times in the past to replicate claims of unknown people with the least support and help from their side. This time we have a fellow experimenter (EmJunkie) who is here between us, willing and trying to push us to a direction which he thinks is right. Even if we won't make it, at least we can say that we tried, without worying that we didn't follow exactly inventor's propositions as EMJunkie is here with us, correcting and indicating of our mistakes..
Jeg
Quote from: EMJunkie on January 23, 2015, 04:08:49 AM
@Jeg,
Dear EmJunkie, do you mean to bring them closer or more far between each other?
i will post a pic in a few hours..
Tnks
ps. Ah i've got what you mean. I have made this inter connection change, and when i shortcuted the output my consumption climbed up to 6A!!! :D (If i didn't make a silly mistake as i was in a hurry there is a lot of difference in the consumption between the two connection modes..)
EMJunkie
Quote from: Jeg on January 23, 2015, 04:26:36 AM
Tnks
Hey Jeg,
Try that too, but not what I meant, I meant, try to connect the Wires from each Partnered Output Coil as per the Diagram, if it does not work one way, try the other!
Kind Regards
