0 Members and 69 Guests are viewing this topic.
EMJunkie
Quote from: forest on April 27, 2015, 03:40:38 AM
Don Smith : "generators don't make electricity"[/size]Harry Perrigo : ""The device is a generator as truly as the power-driven rotary generator in any power plant. Those generators don't actually 'make' electricity. They condense it from the air.""In 1919 Hubbard represented the apparatus as being capable of extracting electrical energy directly from the air"Hendershot : "His earlier invention was called a "motor" by the newspapers, but it was actually a generator which was powered by the magnetic field of the earth. His later models created enough electricity to simultaneously light a 120 volt light bulb and a table model radio."
Forest - You're exactly Right - Welcome to the future my friend!!!
Ref: T H Moray
An electrical generator is, in the true sense, not a generator, as it does not create electrical energy. Electricity is not made by the generator, it is merely pumped. From that standpoint, an electric generator might be referred to as an electric pump and the Moray radiant energy device as a high-speed electron oscillating device.
The Hydraulic Ram Pump is a Self Sustaining Mechanical Device using Gravity and Water as its source of Prime Mover Energy, What could a Charge Pump be capable of?
Red_Sunset
Quote from: EMJunkie on April 27, 2015, 03:45:30 AM
.............................. "If its confusing or over complicated, then one does not understand it"
Why would one want to deliberately over complicate such a simple topic? Ask yourself that!
EMJ,
Complicated or 'difficulty understanding' are relative perception concepts, levels that differ between different people.
I ask myself, why would MarkE want to over complicate a simple topic ?    From what i have seen, I gather he wants to be as complete, thorough and precise in his explanation.
In your subsequent mail, you appear to discover that "Electricity is not made by the generator, it is merely pumped" which is correct. The knowledge of that fact is widely known, it just depends where you are in the knowledge ladder.
Charge pump, Hydraulic Ram, Electric Generator, all require the input of a medium with stored potential energy (this process is well understood & documented)
Hubbard, Hendershot appear to have discovered a way to tap stored potential energy of a not clearly understood origin.(this process is not well understood & neither documented)
None of these unknown concepts will alter the current understood Electro Magnetic Science in any major way except for ADDING & EXPANDING and perhaps clarifying the current understandings.  They are not expected to alter the well known and tested laws of induction, as what was insinuated at in a previous posting with a misleading patent test result.
The future is yours if you backup your words with action.  (always useful in order to hold your position).
Red_Sunset
EMJunkie
Quote from: Red_Sunset on April 27, 2015, 04:32:23 AM
Red_Sunset
Hahaha - What a bunch of garbage - "The future is yours if you backup your words with action"
What Ever!!!
EMJunkie
So now its about position...
According to Red_Sunset - What position would this be? Are we playing Musical Chairs...
See, the situation is, ANYONE here, if they, read, paid attention, understood, and did not spend all their time spewing out a Convoluted Contrivance, then the position, for each and everyone here would be the same, all equal!
Which is where it should be!
The only difference between you and I, is I have spent the years Learning, and Working Hard.
EMJunkie
The most obvious things are the hardest to find - The absolute basics of conventional "Power Generation" and understanding of it, is all you need.
