EMJunkie
Quote from: MileHigh on April 27, 2015, 10:37:57 PM
Drive-by editorial plucked from the Aether......
"Elmer Gantry" is an amazing film that does not seem dated at all, having lost none of its bite or appeal with the passing of time. Taken from the classic Sinclair Lewis novel of the same name, director Richard Brooks garnered an Oscar for Best Screenplay for his adaptation, and Burt Lancaster won his sole Best Actor Oscar for his performance as Elmer Gantry. Gantry is an over-the-top opportunistic traveling salesman who teams up with evangelist Sister Sharon Falconer (Jean Simmons) to promote religion in 1920's America. Gantry turns out to be the perfect publicity compliment to Sister Sharon, who, unlike him, is a true believer. Where she is quiet and gentle with her manner of preaching, he is all fire and brimstone, literally throwing himself about the audience and inflaming them into repentance.
Burt Lancaster commands the screen: all flashing teeth, athletic energy, charisma, and wild hair, using his own physical prowess to great advantage.
Author: Billie from United States
Good to see you back Old Mate!!!
Yes the oldies are sometimes the best!!!
What is Aether MileHigh? Lets have a thought experiment?
Red_Sunset
Quote from: EMJunkie on April 28, 2015, 02:02:44 AM
Human's greatest problem is the Richest 1% - Greed...
There is longer any need for poverty, Hunger, all the terrible things we suffer needlessly!!
War being the absolute worst of all Human traits! For Greed? For Religion? For Oil? For nothing!!! Destruction is Evil!!!
EMJ,
Thanks for the acknowledgement
I hate to disagree that the "Human's greatest problem is the Richest 1%", I do agree on "greed"
"Richest" is not necessary synonymous with "greed"
If the "richest" wouldn't exist, the "poor" wouldn't be necessary less poor, neither would it eliminate all the other terrible things you mentioned.   The real problem is inherent in the human mind where the problem originates from a base core emotion called "fear"
War DOES track back to "richest" since war is money based like any other business activity.  (trace the money and you would find the reason for war)   A good example is the last Gulf war. Who made the money ?   Check around in Texas and other places and you will find)  From their angle it was a "Business project".    For most others, it is usually an emotional experience based on nationalism or Religion or ....., used to give validation to the business project.
If this is of interest, investigate ISIL, how it started, who is financing, why are they are financing,  what possible motivation, interest do they have...ect..   From an investment viewpoint,  it is no different than investing in the stock exchange, only it has a different twist.   As an other angle,  have a close investigative look on "Blackwater",  it gives you an idea where the US and the world is going.
"Wish" is an empty word.
Try to "understand" and follow with action will alleviate poverty.
Red_Sunset
Enjoykin
Hello EMJunkie
Ok let's take a time to finish VTA strory.  :D
I will be on your forum. Wait for you and other memebers in VTA thread !!
Reg.
Enjoykin
EMJunkie
Some Facts about Energy Machines:
In 1968 Raymond Kromrey said:
Conventional generators of this type utilize a winding whose conductors form loops in different axial planes whereby, upon relative rotation of the two members, diametrically opposite portions of each loop pass twice per revolution through the field of each pole pair of the magnetic inductor member (usually the stator)....
The armature carries a winding, advantageously in the form of two series-connected coils embracing opposite extremities thereof, which is included in an output circuit adapted to be connected to a load.
In 1987 Floyd Sweet said:
When we apply the principle of superposition to the vacuum triode it becomes more obvious how the device is in fact operating. The principle of superposition states that; "In order to calculate the resultant intensity of superimposed fields, each field must be dealt with individually as though the other were not present". The resultant is obtained by vector addition of each field considered singularly.
Consider for a moment the construction of the triode which includes the bifilar coils located within the fields of the two conditioned magnets.
When the current in one half of the conductors in the coils (i.e., one of the bifilar elements in each coil) of the device is moving up, both the current and the magnetic field follow the right-hand rule.
The resultant motional E-field would be vertical to both and inwardly directed.
At the same time the current in the other half of the conductors in the coils is moving down and both the current and magnetic field follow the right-hand rule.
The resulting motion E-field is again vertical to both and inwardly directed.
Thus, the resultant field intensity is double the intensity attributable to either one of the set of coil conductors taken singularly. The first term B x V in the equation represents the flow of the magnetic field when the electrons are moving in one direction, while the second term Negative B x Negative V defines the flow of the magnetic field when the electrons are moving in the other direction. These measurements indicate that field intensity is directly proportional to the square of the current required by the load placed on the device.
In 1994 Paul Raymond Jensen said:
An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields.
In 2014 Bill Alek said:
Produces Opposing Magnetomotive Force efficiency >> 100%
Opposing Fields... Its a key feature of building Overunity Devices... @20:22 : https://www.youtube.com/watch?v=tXno_7xXSZs
FYI: I have been saying, since 2011, the same things!!!!
The "Conventional Electric Generator" works similarly, its just Incomplete!!! An Unfinished Device, where Magnetic Fields are still aloud to create Drag - Lenz's Law...
IMPORTANT: Lenz's Law is not gone as such, its still present in the space of the coils. Its just confined, not aloud to spill out all through space like we would normally see.
Enjoykin
KEY WORDS "conditioned magnets"
But.... what does it mean ??
In fact it is so simple you will be laugh !!  ;D  ;D
1st. word "conditioned" mean  -  put magnets in specified condition. To what ??
To scalar magnetic field. H* = - div A. (A is vector potential). what does it mean ??
It mean put mognets at special position to generate scalar magnetic filed H*.
How ??
Answer has gave Great Mind Gennadiy Vasilevitch Nikolaev in 1979 year - make "SIBERIAN COLIA" configuration.
And than ??
Answer has gave another Great Mind Floyd Sparky Sweet - make " two bifilar coils located within the fields of the two "SIBERIAN COLIA" magnets (conditioned).
Got it ??
So simple you will be laugh !!  ;D  ;D  ;D  ;D
ps: "SIBERIAN COLIA" is the original name of 3rd Great Mind Professor Stefan Marinov. How to make "SIBERIAN COLIA" read my earlier post.
ps2: One more hint from me !! :D
Keep in mind that interaction of scalar magnetic filed is different for test (trial) charges which move parallel or perpendicular to H*. It mean - position and orenatation of two bifilar coils located within the fields is very important. In perpendicular case H* = div A and total scalar magnetic filed must be calculated particularly for each case as sum of both cases. Don;t forget that scalar filed is one unique - not two fileds. Difference is only in different physical interaction with respect to parallel or perpendicular charges.
That is all folks !!
Reg.
Enjoykin !!
