0 Members and 90 Guests are viewing this topic.
EMJunkie
@Wistiti
Quote from: wistiti on January 24, 2015, 12:48:53 AM
hi all!
my result until now. (with what i have on hand...)
Tv yoke split in 2 part as the core.The 2 peices of the core have a gap of around 2mm with electric tape and paper. Buckink coil wound on each part of the core 400 turns 30awg each coil. Primary (or trigger coil) 2 strand twisted litz like wire 50 turns over one secondary coil. The primary (or trigger coil) is trigger with a joule thief like circuit. I have a 50k resistor to the base of a 2n3055 transistor for adjusting the frequency.
Nice! If you can, please post Pic! Sounds excellent!
My result clearly depend on the frequency... at some point, when the output is shorted, the amp draw on the input goes higher. But when i tune it to is best, the input went to 400ma no load to 293 shorted! there is definitely something there...  :)
Yes, superb. This is one of the effects!
Nice Work Wistiti!
So, from here, play around, try to improve it.
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
SkyWatcher123
Hi folks, Hi wistiti, yes that is what I am seeing also when using a single transistor blocking oscillator setup, even though my primary is next to the partnered coils and not on top of one of them, seems to function the same.
Though so far with this flip flop driver setup, I am observing a little different behavior, this driver outputs an ac type wave.
The partnered coils when loaded with say a 1 kohm resistor, the amp draw is highest at around 670 milliamps.
When i use a resistor load of 500 ohms, the amp draw decreases from that level.
When i use a 220 ohm resistor, the amp draw drops even further and dead short gives the lowest amp draw of around 240 milliamps.
However, the unloaded amp draw is around 80 milliamps and the unloaded voltage at partner coils is around 32 volts AC with 7.4 input volts DC.
peace love light
wistiti
Hi Em and all!
here is a picture of my replication on a tv yoke core. i play moore with it and i blew the transistor... may be to much voltage ...
I find a ferrite rod inside an old radio i have. I will try on it the next time. very interesting phenomen. Thank again to have share it with us!
Now i have to go sleep; it will be a short night... again! :)
Ciao!
John.K1
Guys,  As I believe it is still about the same I would like to share some findings related to "One way Transformer"  which I believe works on similar or same principle.
Some info what it is here: https://www.youtube.com/watch?v=4fZT7PvEGKU
I have made two types, the larger one is made of inner and outer partner coils and between I have several independent coils (see picture below)  The thing is I tested it with many many LED stripes and more I connected I didn't register any increase in consumption. In fact in some cases it went down- again the result relates to the right frequency.  Also it didn't work as an air core. I had to put ferite rods in to the coils. I wasn't lucky enough to lit incandescent bulb. It probably needs some more tuning.  Any way- same or similar principle.
wistiti
Quote from: John.K1 on January 24, 2015, 03:19:59 AM
Wow!
Good job John!
