0 Members and 192 Guests are viewing this topic.
John.K1
Hi MH.
The video is nice and very clear. I only miss some time propagation in the equation as the magnetic field doesn't appear in the core immediately as you power the wires. The part of magnetism starts outside before is "sucked" inside.  Perhaps the magnetic propagation (B/td) in the core is the next think to take in to the consideration? Under what circumstances can you see the "leakage" of the m.field?
I believe when people do some assumption about the OU in the transformers, they do not speak about simple one wire wound toroid :)
Not sure who has said " There is a free energy in the wire"  - And you know what? I do believe it.
Somebody said " There is a god" - And you know what?  I believe it.
The clip simply discusses the field inside a toroid when there is DC current flowing through the wire.  That is the only issue the clip discusses which is intentional.
Applying voltage at time zero to a coil and observing the increase in current is a completely separate but related issue.  It is also a very well understood issue that in theory everybody that is an experimenter should completely understand.  Unfortunately almost nobody on the forums understands it.  This is illustrated by the fact that only a few people tried to discuss the two-coil example from a few days ago.  When these few people were not correct, then they stopped discussing the example altogether.  After that, nobody had anything to say.  Is that because of fear?  Then of course Chris/EMJunkie and Enjoykin actively worked to suppress even discussing this basic fundamental question and even started to spam the thread with complete junk to actively suppress people from discussing this issue.  They wanted to make you afraid to speak your mind and ask questions in order to learn.  You have head of the "Thought Police" from the famous novel 1984?  This was another form of the same idea, but in this case it was the "Ignorance and Stupidity Enforcer Police."
QuoteThe part of magnetism starts outside before is "sucked" inside.
That is complete and utter nonsense and it is a typical example of the "imaginary belief systems" that people create in their minds to advance their interests.   Where did you hear such a crazy thing?  Why do you want to believe such a crazy thing?
verpies
Quote from: tinman on May 07, 2015, 11:45:28 PM
Still doesn't seem right. That seems to indicate that the outer perimeter has the highest flux density, and the inner part of the core (inner perimeter) has the lowest flux density.
The red color is nearer the inside perimeter and the blue color is nearer the outside perimeter, so I am not seeing what you are seeing.
You seem to have problems reading diagrams so I duplicated and moved these crossections on the top of the toroidal core's outline, for you.
John.K1
Quote from: MileHigh on May 08, 2015, 03:41:50 AM
It is somewhere in the document below. Also I have been watching some of the work of our good man Distinti    at  http://www.distinti.com/     + his YouTube series. :)
Also, meanwhile I just took a toroid coil and put the compass next to. By applying a small DC voltage 1.5 v @ 0.7 A  I could see some alignment on the compass. Shouldn't be all magnetism inside and invisible to the compass?
verpies
Also, where is north and south field In a toroid?. If it doesn't have north or south, then is that a monopole field.
No, it is a circular flux which is an entirely different animal from a monopole.
Lack of identifiable poles is not synonymous with a monopole.
