EMJunkie
Quote from: John.K1 on January 24, 2015, 02:51:15 PM
EMJunkie, to be honnest - 50-50
If that device would work also as Air core  I would say- I do understand. But, because it is not working for me, it means there must be some gap in my understanding. :)
Back to my Air core bucked coil tube. Thinking about it now, it is like two Tesla coils facing against each other and connected together at the bottoms and at the top. Sure winding is in opposite way.  My HV probe doesn't show HV on neither end of the bucked coil, just in the middle(strongest electric field). And my LED probe (small coil with LED) has highest intensity at the bottom and top (strongest magnetic field) and especially inside of the tube. The  continuos flow of current in the bucket coil has large impact on the intensity of my LED probe. When closed loop (shorted with resisitive load) the intensity of light (magnetic field)is High.  So my understanding of the fields structure around the device  from the bottom is   Amps - HV - Amps?
Hey John.K1,
Yes:
QuoteAmps - HV - Amps
is one way to describe a Valve!
Also by definition, Bucking Coils are a Valve!
Another Quote:
"A signal (energy) is transmitted from point A to point B. A and B are separated by a finite distance. Consider three periods of time:
 1) The signal is launched from A.
 2) The signal resides in the space between A and B.
 3) The signal arrives at B.
Now we know that for real space to exist between two points a signal travelling between them will propagate at a finite velocity C, (C = 1/√ue)"
If we were to take a Magnetic Field, Uniform, Two Magnets in attraction Mode, the Flux has a Point A and a Point B!
To Valve this "Signal" means:
"Energy current does have an aspect ratio. If the aspect ratio is forced to change, some of the flowing energy will reflect in order to assure that its total aspect ratio remains constant. Crudely, the aspect ratio is similar to the ratio of E to H, or the same as the ratio of E to u (√e/u ). The aspect ratio of energy current is much like the aspect ratio of space. While the aspect ratio of space can change, it fundamental velocity C = 1/√ue cannot really change. This parameter becomes merely our way of conceptualizing time delay when energy resides in a region of space."
You guys following me?
So here we see Magnetic Gating that has a Time Delay of a particular region of space.
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
EDIT: It is really important to get the devices working First! Then once working, make small improvements! Play with the devices, see what they Like and Don't Like
EMJunkie
Quote from: conradelektro on January 24, 2015, 03:41:13 PM
I prepared a coil former for "partnered output coils" (not yet wound), see the attached photo and specification.
I intend to wind the partnered output coils like this:
- 0.25 mm diameter enamelled wired (~ 30 AWG)
- each partnered coil has 5 layers, each 65 turns --> ~330 turns + ~330 turns
- the input coil is wound over one partnered coil, 2 layers, each 65 turns -->  ~120 turns
I could also wind like this:
- each partnered coil has 3 layers, each 65 turns --> ~195 turns + ~195 turns
- the input coil is wound over one partnered coil, 1 layer,  65 turns -->  ~65 turns
The winding principle will be as indicated by EMJunkie (see e.g. the picture in this post
http://overunity.com/15395/partnered-output-coils-free-energy/msg434472/#msg434472 )
The coupling can be modified by creating a gap between the core halves (e.g. by putting paper layers between them).
@EMJunkie: if you have time, please comment. Does this coil make sense?
Greetings, Conrad
Hi Conrad,
If I may suggest, for your first device, just aim to get working. I am sure you are already, but keeping expectations at a reasonable level, not to high, will yield a better result over all. I know, because I am guilty of this most of the time!
Remember, we must Start at the Start to get to the finish line.
Do these E Cores have a gap on the centre leg? Some do and some don't.
What you've got looks good!
Kind Regards
conradelektro
Quote from: EMJunkie on January 24, 2015, 04:03:19 PM
Hi Conrad,
Kind Regards
The two halves of the E core have no gap at the centre leg, please see the attached photo.
Do not worry, I start at the start. And if I do measurements it would not prove or disprove anything, because your specifications leave room for very many variations which I possibly can not test all.
Whatever I do, I do because I like tinkering with strange devices. I am no expert, whatever I will say has no significance. You can expect (but it takes time) a short video on my YouTube channel https://www.youtube.com/user/conradelektro/videos reporting what I built and measured. After I while I will loose interest, like with all other projects I did in the past.
Greetings, Conrad
EMJunkie
Quote from: conradelektro on January 24, 2015, 04:30:06 PM
Greetings, Conrad
@Conrad,
Excellent! Lots of room with those cores!
@ALL
I promise, for all taking up this journey, it will be perhaps the most exciting ride in your life.
Don't give up! High Expectations and a few failures lead to misery!
Start at the Start and the Finish line will very soon be in sight! Never shut doors that have not been explored, even then don't throw away the key!
Again, make small improvements! Feel what this Technology Likes and Doesn't Like! I like the devices to run at lower frequencies so its easier to Feel what's going on but I cant predict frequencies yet...
Kind Regards
EMJunkie
@ALL,
About Frequency's, a small experiment:
1: Fuse your input just to be safe first!
2: Slowly drop your running frequency down...
3: Hold in your hand, a small magnet, close to your device.
4: Keep dropping your Frequency until you can Feel the Magnet Jump around.
5: Check all around your device with the Magnet
I found this good to get a feel for what's going on. And, yes easy for the sceptics to go to town here, but it did help me.
Also, on a side Note: Start thinking about the potentials of the Partnered Output Coils! Think about each Coil being a Bucket, How much Water can it hold...
Kind Regards
P.S: You should hear a Chattering of your device. Aim for around 25 - 40 Hz to do this experiment.
P.P.S: This Experiment is fairly important, so please don't pass it by! Please Run the Experiment and report your Results!  ;)
