0 Members and 203 Guests are viewing this topic.
tinman
Maybe we have been going about this all wrong.If we look at a simple generator setup,we have our generating coil,and a magnetic field. Lets assume that it is just a straight inductor/generating coil,and we pass one field past one end of the coil,and the opposite field past the other end of the coil. Then at each end of the coil(upon magnets approach),an apposing magnetic field is generated-and this wants to push the approaching magnets away. Then when the magnets are leaving the coil,the magnetic field in the coil flip's,and want to draw the magnets back to it. So is there any reason that the magnetic fields from the PM cannot pass through the middle of the coil where no BEMF will be created. Dose it matter wether the magnetic fields cut from center of the conducting turns out,as apposed from the out side to center.The center of the coil/inductor would still have the neutral point,it's just that each field would get weaker as it neared the outer ends of the inductor.
Red_Sunset
Quote from: tinman on May 12, 2015, 08:43:28 AM
Tinman,
If you see the coil as a whole (wired as one conductor ), then the coil never sees a changing field.
If you break the coil winding in the middle (2 sections), left and right, then you have the same effect as 2 coils , sure the BEMF will buck in the middle in the same way the rotor magnet field does.  I do not see any advantage on first view
Red
MarkE
Fields superimpose linearly.  So if you come up with an arrangement where you are changing one field relative to a wire that induces one way with another that induces in the opposite direction, the reduced net field change just reduces the induced EMF, and consequently the mechanical load reflected back to whatever is causing the relative motions.
To specifically answer your question:  The answer is no.  Portions of wire that are away from the changing field just act like lead wires.  You don't have to concern yourself with those until you deal with signals that change fast enough that those leads look electrically long.
EMJunkie
Quote from: MileHigh on May 12, 2015, 04:38:32 AM
Even when you know that I would agree with most of your recent technical postings you call me a troll.  You are a psychological cluster-fuck Chris.
MileHigh, only for the way you approached this topic, trying to bring the seriousness of it down to a joke.
If you had agreed and not made it look silly then I would have also agreed.
Apologies MileHigh! Lets be serious now!
   Chris
EMJunkie
Tinman, keep asking questions... This is excellent!
Induction is considered to come in two forms. Flux Cutting (EMF = Bvl) and Flux Linking (EMF = - dPhi/dt)
These terms are not entirely correct. They are accurate to a point but do not complete the Solution for Induction. Red pointed part of the Solution out.
SOLUTION:
   1: Take one loop of a Inductor.
   2: Put an Imaginary line through the middle, separating the loop in exactly half. Preferably through the shortest length, not the longest.
   3: In this solution, the total Flux Cutting the loop, one Half of the Loop MUST have a difference in Density to the other half, or a difference in polarity in the Flux on one half of the Loop. So, in other words, if the Total flux Cutting the Loop is Uniform and of the same density, cutting the Loop, NO EMF will be "Generated" - There will be NO Separation of Charges.
The same is true for Flux Linking, the Inductor must see a change in Flux Linking, preferable of half the Windings relative to the other. This example is more complicated to explain. However, imagine a Transformer, Input Coil changes in Time its density, pushing the Core through Hysteresis. The Electric Field Vector changes, the Secondary Coil sees an Electric Field Boundary Change, this cuts the turns in time. An Audible representation of this can be heard here: MIT Physics Demo - Barkhausen Effect
I see that this explanation will be doubted and even disputed, but it is true if one reads the words and puts the meanings together...
In the first post I posted, I included this video: https://www.youtube.com/watch?v=lcGWO_x8tpM
It clearly shows what I have said, and experiments can also prove what I've said is true.
So, in other words, what I am trying to explain, is that Inductors must see a change in Electric/Magnetic Fields (Depending on the Induction Type) and to maximise this change, there is a Ideal solution to maximise the Output, E.G: Half of the inductor's must see a difference in the applied field. Which is not shown in either equations above...
   Chris
