0 Members and 98 Guests are viewing this topic.
jbignes5
Great,
I am glad you had the time to go over my post.
Yes Tesla went the excessive rounds when doing his experiments. But it doesn't have to be that way, up to a point. You need to establish an electric field that will go the distance between each coil and unfortunately the electric field is bound to the magnetic field so a core will be needed. Tesla liked to shield his transformer much like Lasersaber is doing with his Tesla torch, that way he could pump in the very high voltage inside of the shielded box and not have to worry about needing a core.
In fact people have been picking out little things from Tesla's work and using that one thing to get some very interesting results but what if we replicated all of his discoveries from that system.
You are starting down the very path Tesla set before us. Continue as I am starting to rejuvenate my own exploration of this area.
Tesla did some very interesting experiments with this purified dynamic electric field and found out it has some very interesting results when different metals are exposed to the field. Aluminum exploded when put inside of a heavy coil that was excited by this disruptive discharge system. The lower the frequency the more dangerous it became to the human condition. Tesla warned to keep it above 2k cycles to keep it safe to us humans.
Speaking of which, Check out the Chicago worlds fair report. His demonstration will enlighten you to what he was doing.
In that report you will hear about him passing this electric field through his body and aiming it at a copper mass on a table. The copper mass turned cherry red with no damage to his person. Quite an interesting tale and witnessed by many thousands of people. In fact he asked people from the audience to join him on the stage and they did the experiment passing the field through them and into the copper as well with no damage to their person.
The cherry red effect was the copper building huge currents and having no where to go it just accumulated and heated the mass up. I'll see if I can find the report... I think it was in one of the books written about Tesla..
Understand the importance of this above. The field created heavy current in the copper mass. Was it more than what it took to generate the dynamic field??? With his disruptive discharge circuit it most probably was more. Until I restart my investigations I will have to wait to answer that. But I think many others have already gone down that road only to get sniped by the measurement police before they had a chance to work it out fully. Don't let these guys get to you. They are heavily invested in their way of doing things, they don't want people actually doing the discovery again.
JBignes5
EMJunkie
Quote from: jbignes5 on January 25, 2015, 12:08:52 AM
Great,
JBignes5
@JBignes5,
Yes Sir, Nikola Tesla was an absolute Genius! Way before his time.
Yes, the Magnetic Field is a wondrous thing! Illusive and mysterious! We think we know a lot about it but it still holds many secrets!
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
SkyWatcher123
Hi folks, i made some tests with the astable flip flop driver and with some load matching, i was able to achieve 87 percent efficiency so far.
Going to adjust driver part values and play with frequency more and see if it can be improved.
peace love light
Jeg
Quote from: EMJunkie on January 23, 2015, 03:56:15 PM
Jeg,
This may work, but check the turn direction on one of the coils! Best to have one reversed to the other! From what I can see, both coils are wound in the same direction!
Take the Blue input Coil off and wind a 40 turn 32 or similar awg coil as shown:
Kind Regards
Thanks Emjunkie
I'd like to ask you if by adding more turns at the partner coils side, the output voltage goes higher? Do you think it is a good practice to insulate every layer of the partner coils by some tape so to avoid inter-turn arcing?
And something else for everyone. Is it the right time to consider again this circuit shown at the video? Alexander meissner...
https://www.youtube.com/watch?v=WDUpYnA2AY0
EMJunkie
Quote from: SkyWatcher123 on January 25, 2015, 02:07:24 AM
peace love light
Hey SkyWatcher123,
Good Work! Keep it up! It will come good, once you have the right config!
What's your opt frequency?
What's your input Phase Angle?
Kind Regards
P.S: An optimised H-Bridge can be very much more efficient than many other drivers. Worth looking up "MERS" Highly efficient!
