0 Members and 183 Guests are viewing this topic.
MarkE
Quote from: EMJunkie on May 15, 2015, 04:09:35 AM
Well done MarkE - You can Read! Excellent start!
Do you still hold the view you expressed in post #94 or not?
MarkE
Quote from: EMJunkie on May 15, 2015, 05:38:28 AM
@Tinman - MarkE is trying to be Amazing again - Ignore the Troll...
Stan Meyer used a variant of this Circuit. When this Circuit is done correctly, and as I stated before the GOON Squad started the ASSUMPTION Train, it was supposed to a "Resonant" Charging Circuit for a HHO Cell, which essentially was a Capacitor!!!
But alas, the GOON Squad could not keep their Beef Jerky in their pants and went off on all sorts of tangents!!! Some not even completing the Circuit properly and others giving up simply because it was too hard.
This is the Trolls Job!
Very Poorly Replicated Circuits that do not follow any of the given guidelines!
So, Stan Meyer's VIC is now Trollified also!
What a total mess!!! I just shake my head at these Buffoons!
You presented the circuit.  What do you think the scope measures when it is connected as you show it?  What do you think it shows when you move the probe ground connection to the bottom of the resistor which causes as you noted a:  "huge difference"?
tinman
Im afraid good old stans work just didnt work. There have been literally thousands of people trying to replicate Stans HHO system's,and to date,no one has been successful-->there's a reason for that EMJ. People often get confused with current loop system's,and im a clasic example. So much current,but not a drop to use. What i mean by that is,if you draw say 1 amp,the current in the loop may drop by 2 amp's-->it depends on the system as to what ratio you can draw,as to what go's missing in the loop. But more always go's missing than what you draw.
MarkE
Quote from: tinman on May 15, 2015, 05:22:23 AM
The scope would be measuring the big current loop between L1,L2 and L3-not to mention that the 10 ohm wire wound resistor would also be inductive.
I want to know what EMJ thinks he's measuring in this set-up that he published.
