0 Members and 159 Guests are viewing this topic.
MarkE
Quote from: forest on May 21, 2015, 11:06:49 AM
There is only one problem : how to setup transformer to force situation when primary does not see secondary load change.
If you want to drive a transformer secondary from the primary, then by definition you are coupling the two.  One can make the transformer secondary less apparent to one observing primary power by burying the secondary power beneath lots of other power drawn through the primary: reactive and/or real.  The trouble is that is a limitation of the observer and the secondary still gets all of its power from the primary.
EMJunkie
Quote from: tinman on May 21, 2015, 08:41:03 AM
Not much by the look's.
Im waiting for the !!free energy!! part of this thread to show it's face ;D
How ever,i have just finished casting a toroid transformer setup i wish to try. The big difference here is that i have two sets of windings cast into the center of the core itself-->thats right,the windings are part of the core. The plan is then to wind a single power wire around the outside of the toroid as the conductor that carries the current to produce the magnetic field in the core. If the magnetic field is contained within the core as most say,then when the internal windings are loaded,there should be no BEMF seen at the outer power winding-->no reflection shown at the primary. ;D. As i assume this wont be the case,at least i can see what is happening at the center of the toroid core when current is flowing through the outer winding. Maybe the center is out of phase to that of the outer winding-->maybe the current flowing through the inner windings is totally opposite to that of the outer winding-180* out of phase. Who knows,but it's always been something i wanted to try.
Guys, let me ask you,
Energy is Invoked How? (Conventionally)
Energy comes from?
Energy is Pumped from Source: True / False?
Every "Electric Generator" is in-fact a Pump and not a "Generator"! So Understand an "Electric Generator" and you can apply these concepts to solid state devices that I have been showing!
This means, at least two Magnetic Fields must oppose in your Device. An Excitation to bring about a flow of Current is needed. This is your Input.
There are many Geometry's, no right or wrongs! See: http://www.hyiq.org/Downloads/Guidelines%20to%20Bucking%20Coils.pdf
In this document I cover some of the devices I have researched that use the same principals.
I think this may be a little advanced for some people, this is also another configuration: https://www.youtube.com/watch?v=qq_FAwTYlMg
This shows a very simple construction, but much harder to grasp from scratch if you have not done the study!
This configuration can be configured on a Toroidal Core, 2x C Cores or a Ferrite Ring Core...
IMPORTANT: 3:1 at least for the turns ratio is Important, that's 3 on the Secondary to 1 on the primary. Floyd Sweet used a 5:1
   Chris Sykes
       hyiq.org
EMJ:
Your pdf has incorrect references to the Bloch wall, which has been thoroughly discussed.  If a good experimenter built the circuits in the pdf and made proper measurements then nothing out of the ordinary would be observed.  That's probably the biggest take-away from this thread.
Why you have some kind of fixation that alludes to out of the ordinary circuit behaviour is the big question.  Your big teaser is just fool's gold at this point.
This thread needs to sail off into the sunset.  We looked for Fire 2.0 and did not find it here.
EMJunkie
Quote from: MileHigh on May 21, 2015, 06:26:49 PM
EMJ:
MileHigh - Seems to me, that Experimenting your way out of a Paper Bag is not your strong point! Try, thought Experimenting, your way out instead?
You're welcome to your opinions, but never can you prove your Assumptions Correct!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: idegen on May 21, 2015, 07:49:47 PM
Where is the source?
What is the source?
Battery?
Ether?
UFO?
Ground?
The Earth's magnetic field, which is permanent?
Troll?
Cosmic radiation?
Refugees?
Slave?
Squirrel on the wheel?
Or the day?
Okay, fine.
only to be fed back for more
Oh, and get out!
used for feeding pets.
I mean: to educate a child slave.
This is a big bullshit.
The end!
The free energy for more than a fanatical search.
The worldwide social problem in the mirror.
Free energy box is not working.
Free solar energy and earth together.
Man has stolen the real free energy.
Other people are forced servitude.
Why able to sponge the man in man?
Like a parasite?
Where are you taking it on the road?
Idegen - A small amount of thinking is required on your part - Your expression of frustration will not help you.
By reading your Private messages, you may see something useful.
Also by reading my recent posts and viewing the attached Pictures, this may give you a little bit of direction...
But, your expectation of Free Energy on a silver Platter, dished up by a free and willing butler is, well, never in your lifetime going to happen!
Pull your head in, do some work, do some reading and pull your Finger out! Stop complaining like a little girl!
