0 Members and 47 Guests are viewing this topic.
Quote from: tinman on May 25, 2015, 09:32:03 PM
It would be nice to continue on with experimental data insted of continuing insults.
Poynt has managed to show the same kind of effect with his sim as i have with my setup. So we know that the effect can be replicated. Now im just waiting for his power disipation ratio's from L2 during the on and off time of L1,and see if he can get a 1:1 ratio like i have. Then come's the agreement between us all that both my DMM's and scope are reading true value's. After that is done,i will present my P/in and P/out value's-but not before. All test from here on in will be done using a set value resistance as the load,and this value is 33 ohms-3 x 100 ohm resistors in parallel
Yes, it would be nice. EMJunkie, however, is following the Rosemary Ainslie False Claimant Script to the letter: now he's burying pages of real results and discussions behind pages of his own comments which contain nothing but insults and false claims without support.
Here's a scopeshot from my build of the system, following Poynt99's sim. This is a scopeshot across the bulb load. I'm using a different mosfet pair, 2ea.  IRF640 in parallel.
This is using an unpotted random toroid with 10 turns "primary" and 30 turns "secondary" of insulated hookup wire.
EMJunkie
Quote from: TinselKoala on May 26, 2015, 03:54:03 AM
You are an incompetent liar.
I have never lied, Ever! - Not like you do TK.
Thing is, you know it! Just your frustration, because you cant do it  ;)
Not smart enough!!!
Hahahaha
tinman
Quote from: TinselKoala on May 26, 2015, 04:20:32 AM
Looks like the off time current flows to about the mid way point between pulses,and then hits that bump at the 0 volt line-is this correct TK,as it is hard to make out the horizontal lines in that pic.
tinman
Quote from: hoptoad on May 25, 2015, 08:57:55 PM
Hi Tinman. What is the coupling like between the two sets of coils that are wound on the inner toroid core. Have you tested the coupling between them by using one as a primary and the other as a secondary?
Thanks for sharing your experiments on Youtube.
Cheers.
The coupling between the two inner windings is good-as we would expect. But i cant get the current to flow from one winding for the 95% off time like we see when using the outer winding as L1.
