0 Members and 51 Guests are viewing this topic.
EMJunkie
In my posts, I have given all readers, more information than any other...
The entire secret, How, Why Where and Why!
If the likes of TK and co are too damn DUMB to put it together and make it work... Well History will reflect very badly on them!!!
The Genius's that cant make it work!!!
I have given you, Free Energy, Over Unity, what ever name you want to call it, I have given it to you, the reader.
The Right Hand Rule is the Key to making these Coils work! In-fact all my posts have bits of information in them.
I mean, really, How many times can it be put right there in-front of you before you take notice and connect the dots. I have explained the entire thing!
   Chris Sykes
       hyiq.org
MarkE
Quote from: EMJunkie on May 26, 2015, 04:55:10 AM
You have supplied ample misinformation.  That includes your false claims to over unity.
There is no technology secret that you either have revealed or have to reveal.
You have failed to show that you can assemble a working device such as you claim.
No, you have given out a string of lies that have been repeatedly exposed.
Whatever bits of information that you have published, none lead to a working free energy / overunity device.
   Chris Sykes
       hyiq.org
How many additional times will you make the false claim that you have found a way to make a working free energy / over unity device?
EMJunkie
Quote from: tinman on May 26, 2015, 01:05:37 AM
Chris
I know you must have your reasons,but i see most people here are here to help.
I have made no claims of any OU device,so i dont see why posting measurements here would call up your goon squad.
I am posting results piece by piece,and am still undecided as wether to posting my P/in and P/out measurements anywhere at all. I am well aware of what comes after that,and this is the very reason for carrying out all requested test-along with my own.
I could just throw up a video !of say! two identical caps-one the input with X amount of volts in it,and one on the output with 0 volts in it. We switch on the FG,get the fets switching,and then hook up the input cap to the system. We let the system run until all energy stored within the input cap has been consumed,and we then see that we have a higher voltage value on the output cap(which is identical to the input cap in every way)at the end of the run. We then swap the caps around,and run the system again,only to find at the end of that run our input cap now hase 3.2 volt more in it than what we started out with in the first place.
Now see-something like that would get the juices flowing all over the place,but what if there was power coming into the system from some other source?.
This is why i go piece by piece,test by test,and make no such claim to the test above. ;)
Tinman - I am glad you think people are here to help. Some are, some are genuine!
I have identified at least four absolute Disgraces to the Human Race.
The Devices I have build, are real, all day every day, they put more Electrical Energy out than I have put in. Its not a Claim, its real. But, really, I am not worried who would, and would not like to see science for what it is, I mean the answer to all the "Mysteries" is right in-front of their eyes, the eyes of those who search. It is so obvious, that its impossible for the basic Insane mind to grasp! I unfortunately have no Cure for the Insane!
I have had several people come forward verifying this on this thread alone!
I have already been through where and how Energy is made available on the Terminals of a Conductor! If you study closely, you will see the same. The problem is, your device will be very hard to Diakoptically assess the basic principals to really find out exactly what is going on. I can be sure that the source is the same as the method I have already shared. The process of how you have gotten to this point may be slightly different.
Many years back, the leakage current from the Fett was enough to bring about a continual oscillation of a simple device. The builder is actually on this forum as a current user. I replicated this device, it did work, as was stated. This may present a problem for your Cap Measurement experiment and may actually impede your end result. So something to watch out for.
If you are able to Separately measure the Magnetic Fields in your device, I would be pretty confident that they are doing a very similar thing to what I have already described. There will be a space stress on the Fields, One changing faster then the other. If you can think of experiments to somehow check this, I firmly believe this will give you some answers to your device.
The earlier BH Curve experiment I suggested is also worth checking, to see if you get a nice clean BH or not. I bet not!
I am also a firm believer in experiment one bit at a time. This is essential.
See, when one really understands something, properly, not just thinking one does, but really understands something, its because ones mind has clearly and methodically processed every single bit of information possible.
Watching someone do a video, judging and assuming without having done any investigation at all to verify such, with absolutely no understanding of how Electrical Energy is made available, surely constitutes Dogmatic Science at its worst possible inception - For this reason alone, claims of others of any kind are ridiculed! Not because the "Learned" know, because they simply do not! They can not, and will not.
   Chris Sykes
       hyiq.org
hoptoad
Quote from: tinman on May 26, 2015, 12:06:05 AM
snip.....
,but when have you ever seen an inductive kickback produce 100% of the power of the forward on state power-(our 5% on time)with inductive coupling-transformer effect.
Good question indeed, that's why I'm finding your experimental toroid arrangement so fascinating.
The greatest amount of power I have ever off loaded from a collapsing field kickback is approximately 25% of the original input power.
Cheers
forest
Every transformer is always 200% efficient unless we construct them to generate hv spike instead of a copy of original energy put into. This knowledge dissapeared somehow around year 1900, with just a few later inventors stepped on this acccidentally.So we had press reports abour C.Earl Amman, Hubbard , Hendershot and few others between 1918 and 1939 .
The copy is the actual output and I have theory that it is taken from external force field - Earth magnetosphere. The original energy is always in primary and dissipated as heat or radio waves or HV spike.
