0 Members and 66 Guests are viewing this topic.
shylo
Is it just not a matter of when the primary is cut ,the field needs to collapse?
As it collapses , it closes in on itself, as it closes in it gains momentum, just like water going down a drain?
Like the ice skater that spins on the spot , the more she closes in the faster she goes??
FG -frequency generator?
SG - signal generator?
Aren't they the same?
artv
tinman
Quote from: minnie on May 26, 2015, 02:21:09 PM
   Good Koala!!
               great demo, it helps a lot that you've increased the brightness - the grid
  lines are much easier to see.
        One thing I do wonder is how does the Tinwoman put up with hours of tinkering?
              John.
Because i can,unlike your self who seems to be nothing more than a keyboard jockey.
And it's a good guess that your one of my resident thumb downer's on my youtube channel lol. Well as long as im keeping you busy ;D
tinman
Quote from: TinselKoala on May 26, 2015, 02:01:26 PM
@TinMan: In that last scopeshot you posted, I see that the trigger level value is shown as -200mV... but the trigger symbol is 200 mV _above_ the zero baseline... does this mean that you have the Yellow trace inverted on the screen?
Yes-yellow trace is inverted due to the probe's sharing a common ground. I could have swapped the wires over on the output coil,but it's easier to push a putton.
tinman
Quote from: TinselKoala on May 26, 2015, 01:55:19 PM
OK, then... here's another pot-core, with a "secondary L2" of 90 turns of #34 wound onto the small bobbin first, then a "primary L1" of 30 turns of #27 wound over that. The load is the same 3 ea. 100R carbon resistors in parallel.  Again, I've shown the trace with the peaks (24 V) clipped off to emphasize the negative portion of the trace. I've also turned up the brightness of the grid!
So now the time constant has increased and the negative portion is more horizontal and still significantly negative by the time the next pulse comes along.
@TinMan: as far as I can tell the two halves of these little potcores mate perfectly with no airgap either at the central core or the outer edges. Of course the bobbin means that there is some airgap inside between the windings and the core itself.
TK
Now that you have it much the same as mine,are you able to do a power disipation measurement of the output coil-power disipated through the resistor during the 5% on time,and power disipated through the resistor during the 95% off time.
Thanks.
EMJunkie
Quote from: shylo on May 26, 2015, 07:24:42 PM
artv
@Sholo,
Yes, time rate of change of the Magnetic Field's relative to the conductor...
I believe, Tinman's device is using a technique, I call and many will understand as a Delay Line effect. The Speed of the Change relative to one Core Material relative to the other is creating a Space Stress of the Fields. In other words, one is changing Much faster then the other!
MarkE did well to point out the above mentioned observation!
Function Gen's and Signal Gen's are often thought of as the same things but they are different, technically: http://www.eevblog.com/forum/beginners/what-is-the-difference-between-a-signal-gen-and-a-function-gen/
Energy is E = MC^2 - The source is everywhere, its around us, everywhere, it is us. Every quantum interaction requires Energy of some kind, every Electron in orbit around a Nucleus, every Nucleus, all are Energetic in Nature, everything is Energy!
I have been through the energy thing about a hundred times but seems as if no one is paying attention.
   Chris Sykes
      hyiq.org
