0 Members and 54 Guests are viewing this topic.
minnie
  Managed to reduce size of photo, am quite amazed!!
          John.
nelsonrochaa
Quote from: Thaelin on June 06, 2015, 03:12:55 AM
Just for Minnie:
   Some times being just plain old fashioned is worth its weight
in gold. The tube era will stand tall a long time to come. Just cant
beat the "warmth" and "glow" of them. Can do things with them
that will blow holes in fets and such.
   I even have a one transistor radio that uses the infamous CK722
transistor. Runs on a 1.5v batt.
For the good times.
The same happens with magnetic amplifier .  We have lot to learn with "old fashioned" things.
EMJunkie
Quote from: nelsonrochaa on June 06, 2015, 09:38:47 AM
Hi Chris ,
as i say in other occasion to you , i have some "different view"  about what you call partnered coils .
But i think basically have same common aspects . I think the biggest difficulty  for people who can not play with this type of circuit is related with some difficulty putting the circuit in resonance;  a small value can simple change everything.
I work actually with that freq (5khz,13khz,15khz,19khz, 27khz) and i can see relation in some particularly freq even i change the coil configuration .
The other thing is assuming that negative currents cant do work  . but it can ! by some particular function in circuit.
I never put the word Overunity in the Table and i don't want talk about it in this moment. My first concern is only observe , learn and improve efficiency.
I left part of my opinion about that subject  .
The radiant energy system is a self-oscillating capacitive system. Once it is set into oscillation, very little power is expended in keeping it going. Because it is an electrostatic oscillating system, only a small amount of charge moves through the system per cycle, that is, the coulomb per seconds = amps are low. If the charge is used at a low rate, the energy stored in the system will be turned into heat at a slow rate enabling the oscillations to continue for a long period of time.
Such a "sink" has to be at a lower energy state than the surrounding medium and, for the energy to continually flow into it, the energy must be continually pumped out of it. Additionally, this "sink" must maintain a lower energy state while meeting the power requirements of the load attached to it. Electrical energy, watt-seconds, is a product of volts x amps x seconds. Because the period of oscillation does not change, either voltage or current has to be the variable in this system's energy equation. Bifilar wound coils are used in the system because a bifilar wound coil maximizes the voltage difference between its turns, the current is then minimized.
Thanks
Hey Nelsonrochaa,
There is nothing wrong with having a different opinion about this Tech!
I have deliberately broken this down to the smallest byte size digestible chunks I can to get people started! Like I said to Poynt99, there is more going on under the hood! I really don't want to complicate this! The biggest problem in the past is some have made this mystical, therefore it becomes unreachable for others!
This is WRONG! EVERYONE can do this! Think about this in a Simple way and the rest will follow!
I have seen your work for some years now, we have shared information. You've got some good things going! Well Done!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: minnie on June 06, 2015, 12:49:59 PM
Me and daughter
@John
That's awesome to see John! Many don't have time to spend with their Kids these days! I call them Day Care Kids!
It is great to see you have such a good relationship with your Daughter!
P.S: Make sure you back up all your photos before making changes to them! Saves on any possible loss of Resolution!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: idegen on June 06, 2015, 05:20:04 PM
Junkie!
This experimental discovery of the permanent magnet generator.
Can you feel the force?
toss when approaching
Moving away from retracting.
So what?
This is not an extra power!
You do not understand the fundamental laws of nature?
It will take a minimum of 50 years.
But there are few who understand this life.!
You do not believe man-made laws of physics.
okay
That's your business.
The laws of nature do not you understand?
I did not write, not people
Tomorrow you can eat what you ate yesterday?
Stool more? like for dinner last night?
Believe me, that older people are not stupid.
The Council of Elders is not an accident!
applicable experience
@Idegen - What you believe, is your business, even if it is wrong!
If you, consider yourself an Elder then the entire world is doomed!
Are you Hungarian for Stools? Is this what you meant? Hahaha you act like a Dufus too!
If you're happy to be bound by Laws set by a few Old Dudes that had no interest in applying logical engineering to the very same Laws, then this is your choice!
Just don't get stuck in your Roll of Sellotape!!! You Dufus!
   Chris Sykes
       hyiq.org
