0 Members and 60 Guests are viewing this topic.
tinman
So here is where im at with V3 of the rotary transformer. Adding the bucking coil setup did indeed increase the overall output of the system-both mechanical and electrical. When i say bucking coil,i mean a coil that acts as a magnet that can be switched on and off at the right time. As it is a coil that is being shorted,and thus becomes an electromagnet that pushes against the rotors collapsing field just at the right time. This field also travels around the stator core,and boost the field within the secondary(generating)coil that provides the power for the globe.
So we do have a coil that is bucking both against the rotor's field and also the field of the generating coil.
https://www.youtube.com/watch?v=ai7rqm9lAlk
woopy
Quote from: tinman on June 20, 2015, 06:15:34 AM
Very good work Tinman
If i understand correctly , when there is no load, the motor draws about 27.7 watts (13.4 volts x 2.07 A )
when the bulb is on your motor draws about 10 watts ( 13.4 V x 0.75 A ) and the generator produces about 18 watts (10.4 V x 1.64 A)
Very interesting can you please élaborate on the motor and the bucking circuit
Thank's for sharing
Laurent
tinman
Woopy
QuoteIf i understand correctly , when there is no load, the motor draws about 27.7 watts (13.4 volts x 2.07 A )
Thank's for sharing
There is a bit more to it Woopy,but thats as far as we go ATM in regards to information.
I once thought that the lockridge device was some concockted BS dreamed up by hudini and his band of clowns-just as a cash injection-->but now im not so sure,and may have to eat my words.
What i will be doing(once again) is showing you all the very basic/initial setup,and from there you guys will have to do your own thinking,as im not doing it all for ya's.
woopy
Tank's Tinman
waiting for your info and will try a replication ASAP
Laurent
allcanadian
@picowatt
QuoteQuite a few people claim to have free energy devices, yet none have been
confirmed by a qualified third party or made available commercially.
I would agree however I have a small circuit on my bench which injects a low voltage current into a high voltage current but it does not use an inductor to boost the voltage nor does it use capacitive doubler/triplers etc... . It works but has not been confirmed by a qualified third party or made available commercially, does that mean it does not exist despite the fact it's sitting on my bench working right now as we speak?. I should note it is not free energy or overunity it's just a simple circuit using a few components which injects a low voltage current into a higher voltage AC or DC current and energy is conserved.
The thing to remember here is that just because you did not think of it or understand how it works does not mean it cannot work or cannot exist, it means you do not have all the facts to prove the matter for yourself. The other option is to believe anything we personally cannot understand cannot exist and I think we all know where that leads and this was the same kind of mentality used in the dark ages. The fact remains that there is infinitely more that we do not know than we know and judging anything based on a lack of real facts is generally a losing proposition.
Do the circuits proposed here in this thread work?.... I don't know, that is the correct answer generally given by intelligent open minded people... I do not know because I do not have all the facts one way or the other.
AC
