I will try to find the time tomorrow to look at your clip a second time and take notes.  You are presenting the data, you owe your audience a summary of the results either in the clip itself or when you post the clips.
You know I have this issue with you.  The last time I recall you posting a schematic is was half-assed and incomplete.  Work on presenting your data and your results and your conclusions in a more professional manner.  I am fully aware that if you do a clip and it's a one-shot deal then it may not be so easy to do that during the clip unless you prepare yourself before the clip so that you can include your results and conclusions in the clip itself.  If you don't prepare yourself before you make the clip then there is nothing stopping you from presenting your data, results, and your conclusions in the text of the posting that includes the link to the clip.  This is just a common courtesy for your audience.  Like I told you before, we are not in your "bubble" and "inside you" when you make a clip.  Work on improving your presentations and extend a common professional courtesy to your audience.  That will make things much much clearer.
MarkE
Quote from: tinman on June 20, 2015, 09:31:59 PM
Well im not sure what video you were watchin MH,but the measurements were shown very clearly in the video. The voltage across both the globe and motor were shown with the scope,and the current through both the globe and motor was shown by the DMM's.
The yellow trace shows voltage across the motor,and the blue trace shows voltage across the globe. The rear amp meter shows current through the motor,and the front DMM shows current through the globe. I am not sure how much clearer it can be shown.
I can also assure you that i know exactly how my device is working,otherwise it wouldnt work at all as it dose. Im not saying that EMJ has a working device based around what he claim's,but i am saying that there is truth in that bucking magnetic fields can do useful work. Also remember that this is a project i have been working on for over 3 years now,so it started long before EMJ started this thread-->the video's are on my YT account.
Tinman, the power that matters is the power that is drawn from the power supply and the power that is applied to the load.  Do you have measurements of: voltage and current from the battery with and without the lamp connected, in addition to the voltage across and the current into the lamp?
picowatt
Quote from: tinman on June 20, 2015, 09:21:36 PM
You mean 2.222 amp's im guessing?. When the light is switched on,the motor bogs down(as can be heard in the video),and the RPM's have decreased. When the light is switched off,the motors current draw go's up,and slowly drops until the motor has once again reached running speed. The 2.07 amp current draw you see at 3.30 is the motor running at full speed(no load),and the current draw of 2.222 you see at 6.27 is the motor picking up speed after the load is disconnected. That current draw will drop back down to the 2.07amps once the motor has once again reached running speed.
Yeah, like I said, 2.222 amps.
Cleaned the glasses and had another look...
PW
tinman
Quote from: MarkE on June 20, 2015, 04:17:07 PM
Could you do me a favor and post a hand sketch that shows the measurement connections, and the external circuit (no secrets exposed) with the lamp connected and disconnected?  I don't want you to reveal any details of the motor or the control circuit.  Thanks.
Below is the schematic you asked for. There are parts left out. They are not electrical as such,but are vital to the operation and performance of the device.The schematic below shows all electrical connections and test measurement points. There are no ground loops or any other type of something going on here,as it operates just the same with the scope disconnected.
Im not going to open another thread,as it will just be a thread without information to the workings of the device-->and what good is that. MH asked to see what i have,and MarkE said that would be fine to place here-->so here it is. As i am using the bucking coil effect(although in a mechanical situation),i see no reason why things just can stay right here on this thread,as i really dont have much more to show-->other than the base model i am willing to share-->the building blocks of which the device is made from. People will just have to use there own brains,and put the missing pieces in place.
I have spent many hours last night looking at all the information available on the mystical lockridge device. And as much as i hate to say it,it looks like that is !almost! exactly what i have built,although i cant find exact plan's as to how the lockridge device is built,but more so what others in other places have been basing there builds around. I think they are missing a vital component though.
Most say that if you stretch or compress a spring ,when you release it,you only get back as much energy as you used to stretch or compress it in the first place. I dont think they take into account the concussive wave created around that spring when released. With magnetic fields you get two things happen which act much the same as that spring. You get electrical forces along with mechanical forces,and both these forces create concussive waves. In this situation(the RT) you use a primary electrical force to create a secondary electrical force,and that very same primary electrical force is also creating a mechanical force at the same time. The secondary electrical force also add to the mechanical force,and the mechanical force generates/adds to the secondary electrical force-->this is the concussive force.
tinman
Quote from: picowatt on June 20, 2015, 10:18:49 PM
PW
PW
Your post says .222 amps,not 2.222 amps lol.
That is what had me confused.
