0 Members and 97 Guests are viewing this topic.
This answers all your questions about a transformer:
propellanttech
Quote from: MileHigh on January 27, 2015, 12:01:58 PM
You just made my point. You think because those equations are from people, oh say, more than 100 years ago, and the fact they call it law, there are no exceptions.
Now prove they tested every instance where those equations came into play.
Now you see, why you will never be able to think outside the box. There is always an exception, except the absolute that there is always an exception.
Thanks MH.......you prove the point exactly.
James
Quote from: minnie on January 27, 2015, 11:58:50 AM
   Geez Cap'n,
               everyone (almost) cites the Wright brothers. Very few seem to realise that
it was the wretched petrol engine that enabled powered flight to take off. If the Wrights
hadn't succeeded very soon someone else would have.
   Evolution is unstoppable, just like an OU. device would be. I think there's far more
likelyhood of murders being committed to get hold of an OU. device rather than of the
oil company trying to block one.
                 John.
Indeed, the Wright Brothers business is a false argument.  It was an era were most people including newspaper editors did not have a scientific education.  It was the newspaper editors that were saying that powered flight was impossible.  The actual scientists that were interested in aeronautics, like the Wright Brothers and their peers doing similar things all around the globe - they firmly believed that flight was possible and it was just a question of getting a suitable power plant.  They even knew the approximate power to weight ratio they needed.  Then the gasoline engine came along and we all know what happened.
The "Wright Brothers argument" is one of the most tired, lame, and untrue arguments out there.
minnie
      James,
               are you looking for more than 100% out of your transformer?
If so it's got to come from somewhere. There must have been billions of
inductors made, coupled and otherwise, has anyone by accident made one
they couldn't turn off?
                        John.
James:
QuoteThanks MH.......you prove the point exactly.
The rate of change of magnetic flux that passes through a loop of wire determines the amount of EMF generated in said loop of wire.  This is TRUE, and you can do your own experiments to confirm that it is TRUE.
All transformers, regular or bucking or toroidal or whatever, are all based on this fundamental property of Nature.  There is no workaround, no secret sauce.  You can bang your head on the wall until the cows come home and it will not change.
So I would suggest to you that you suffer from failure of the imagination:  You can look at any possible transformer configuration that you can imagine and distil it down to loops of wire seeing changing magnetic flux.  If you can't see this or you fail or refuse to see this then you are blind.
You are failing to look at a complex transformer configuration and distilling it down to a simple, elegant, and universal concept.
If you can take a complex problem and reduce it down to a very simple solution that anybody can understand, that's a very good thing.  You are failing to do that.  It's a failure of the imagination and that's an unfortunate thing.
