0 Members and 25 Guests are viewing this topic.
EMJunkie
Quote from: synchro1 on June 25, 2015, 03:43:23 AM
@Tinman,
              I failed to spot the FET in the test schematic Chris uploaded. Awesome COP! Try and self loop. Just attach those light wires to the battery electrodes.
@Synchro1,
I have never ever done this so called "Shorting"!
Please, make no assumptions here! Partnered Output Coils require no "Shorting"!!!
   Chris Sykes
       hyiq.org
hoptoad
Quote from: EMJunkie on June 25, 2015, 05:12:09 AM
snip...
So, some questions, ask yourself, what's going to happen when a "Shorting" occurs?
   1: Cap will be short Circuited
snip...
Well, actually no, not according to the diagram. One side of the shorted coil circuit output connections to the main generator circuit and storage capacitor is via a resistor (of unspecified value).
Cheers.
EMJunkie
Quote from: hoptoad on June 25, 2015, 05:41:48 AM
Well, actually no, not according to the diagram. One side of the shorted coil circuit output connection to the main generator circuit and storage capacitor is via a resistor (of unknown value).
Cheers.
@Hoptoad,
You're not wrong, however, this depends weather you believe this is a base Resistor, or a Pull Down Resistor as there is only one in the entire circuit?
Adding a resistor to the Coil in question, is not of any benefit where it currently is for Output Power.
   Chris Sykes
       hyiq.org
picowatt
So, "Shorting" is a very unlikely methodology here! Maybe this should be termed "Switching In" the Second Partnered Output Coil instead! You need to really look at this is some detail! Make NO Assumptions here, be open and ask yourself, "What is it that Tinman is actually, so called, "Shorting"?"
I believe Tinman is a bit more qualified to describe the operation of his circuit...
EMJunkie
Quote from: picowatt on June 25, 2015, 05:55:19 AM
Yes, PW, you're right. This is Tinman's design, he made it work, he is the Inventor.
He has done well and it is his choice if he decides to show what's really going on.
Importantly, this is one of hundreds of ways that Partnered Output Coils can work, so I urge no one to limit themselves! Use what information you can, then use your own intuition! Become your own inventor!
What Tinman's Invention does show, is that Partnered Output Coils work! Its real, simple, cheap to work with and what's more it can be made to work many ways!
   Chris Sykes
       hyiq.org
