0 Members and 94 Guests are viewing this topic.
QuoteLet me ask you, If we could take all the Energy out of a Magnetic Field instantly, what would happen?
Across two terminals, you get an energy pulse of infinite voltage, zero duration, finite current, and finite energy.
QuoteMind blowing isn't it!!!
Not if you have been taking Spice and have blue eyes.
EMJunkie
Quote from: tinman on June 26, 2015, 10:17:14 PM
If you take all the energy out of a magnetic field in one instant,then you would have less energy than what it took to create that field. you would also have a piece of material that in now as good as a bolt sitting in your parts tray.
Why would you want to remove that field?,why not let the field serve it's purpose within the device.
If we were to use say a PM,then would it not be better to neutralize that PM's field until such time as it is needed to provide a force?--both mechanical !and! electrically.
@Tinman - An extremely interesting answer!!!
I suggest you take some more time to think about the Magnetic Field. Break the Field down to the absolute Base Levels.
What is Entropy? System Equilibrium?
How is it that Earth's Magnetic Field has remained, through out its Cycles, for so long?
   Chris Sykes
       hyiq.org
tinman
Quote from: synchro1 on June 26, 2015, 10:15:11 PM
The arrow in the symbol of the diode points to the direction of the conventional current (flow of + charge).
That is correct,and thus current cannot flow in the direction of the yellow arrow's(through coil A),but only in the direction of the red arrows(to the cap).
MarkE
Quote from: tinman on June 26, 2015, 10:23:55 PM
Do you want to let on what that does to EMJ's most recent representation of what's in your shorting circuit box, or do you want to just let him continue to flounder?
I note that even with S1 open you have a conduction path between the shorting coil and the load.  It's just an observation and I am not getting involved in the analysis.
