0 Members and 90 Guests are viewing this topic.
picowatt
lasersaber
QuoteOne would think that with all the pulse motors i have built that charge one battery while running from another-this would have been one of the first things i would have done [/size]-->but i never gave it a thought.Im heading back out to the workshop now lol.
TinMan,
What is the no load voltage output?  I see that it is around 9V loaded but I am curious what it is without a load.  If you already stated it in one of the videos, I must of have missed it.  I have not even tried to look for it in this thread, because it has become really cluttered.  Are you discussing this somewhere else on any other forums or threads?  It is rather time consuming to filter through all the personal stuff that is going on in this thread.   By the way, I thought your window pulse motor was awesome!  I had never seen that build before.  Very nice work.
poynt99
Brad,
As I mentioned at OUR, trying to charge even a different 12V battery isn't going to work, because your output is only about 10V. If you try charging a 6V battery, then it may work.
However, I think the best solution would be to buy that boost DC to DC converter (or something similar) so that you can not only charge the 12V run battery, but adjust the charging voltage, effectively allowing you to change your load for optimal power transfer.
gotoluc
Quote from: tinman on June 28, 2015, 06:45:47 AM
Here is the next test video.
https://www.youtube.com/watch?v=paJbNcmJCac
Thanks Brad for this excellent test. Having a separate Voltage meter on your input battery has made this very convincing, as now we can also see the battery recover when you apply the load. In you prior test using the scope to measure battery voltage I never saw a change in input battery voltage when you switched the load on and off. I couldn't understand why no change in battery voltage when the input was dropping by over 1 Amp under load. Now we can clearly see the battery recovery.
This way of measuring and filtration should be the standard for anyone wanting real results.
.99 suggestion above seems good.
I have no home at this time (living in my van) but I'm very excited about what you have found, so today I'll be pulling stuff out of my storage and will try a replication of your effect.
Thanks for sharing what you can to this point.
Luc
picowatt
Quote from: poynt99 on June 28, 2015, 08:54:04 AM
Brad,
.99,
It would be interesting to see what Tinman's in/out measurements look like with a few different loads on the output.  So far, we have seen the one lamp that works out to a 6R or so load.  I wonder what the in/out numbers look like with two or three lamps in series on his output.
His motor, when loaded, appears to be around 16R.
Also, in his first video, Tinman had the battery minus and output cap minus tied together thru his scope probe grounds with apparently no ill effect on the operation of the device.  Being able to intentionally connect those two points together would eliminate the need for an isolated converter, if a converter is indeed required, and allow direct out to in looping tests.
I suggested using a couple diodes, one from Batt+ to motor in, and another from output cap+ to motor in, to see if the output can pick up any of the input load as the load on the output is decreased (thereby allowing the output V to rise).  But before doing so, I would want to see the results of in/out measurements at various output loads (and again, only if the Batt- and output cap- can be tied together)
Always great to hear from you...
PW
