tinman
Quote from: MarkE on July 19, 2015, 09:48:15 AM
But the energy required to magnetize the coil does change.  This has now been explained to you more than half a dozen times by Verpies and myself.
With regards to an air core coil,regardless of the presents of a magnetic field or not,no more energy is required to magnetize the coil in order to gain a higher force in the presents of a PM.
Spilled Fluids
Quote from: tinman on July 19, 2015, 09:40:08 AM
Dear mister !my rocks wont bounce!
I gave you an experiment to carry out that shows a PM doing useful work. It dosnt matter what situation that PM dose that work in,weather it is additive to an existing force or not.
You(like all others so far) have failed to prove me wrong,and in stead,you hide behind irrelevant excuses. It dose not matter how that PM dose the work,nor dose it matter in what situation it dose it-->the fact is,it dose useful work. Now stop hiding,and explain as to how it is not doing useful work in the experiment i gave you-->you are yet to answer.
You absolutely did not give me an experiment that showed a PM doing work. You gave me an experiment showing an electromagnet doing work. It is completely irrelevant if you used a ferrite, a PM , an iron plug or a block of wood. None of those are doing any work.
To your inane and relatively stupid question, there is no answer since the PM is not doing any work, period.
By you arguements I could put a brick in the trunk of may care then measure the car's acceleration and compare it to the same car with two bricks in the trunk. Neither brick is doing a lick of work; it is the engine or the electromagnet in your experiment.
verpies
Quote from: tinman on July 19, 2015, 09:31:54 AM
Time is not a factor in the test,as it is an applied DC current,
...but it is :(
This is because when you start applying that "DC current" this current does not rise instantly, and it is during the time when the current rises, that the energy transfer takes place.  Please, please read this carefully.
...and this current may be applied to the coil for as long as you like.
...but during the application of this current not all of the energy carried by it goes into the building of the coil's magnetic field.
After 5τ almost none of it goes to that purpose and almost all of it goes to heating the winding.
The point of the test is to show the force applied against the spring
Force is not energy either.  Integral of force * distance is energy.  However the distance that a given spring is extended indeed is a good representation of potential energy, even if distance is not energy ;) .  ...so I have no qualms about this part of your experiment.
with a set amount of power/electrical energy,what ever you like to call it on the day, flowing into the coil.
That is the point. After 5τ almost none of the electric energy is converted into the coil's magnetic field
Please do not synonimize power/energy with a slash.  They are not the same and it creates confusion for other readers.  Power is a concept that illustrates how quickly energy gets transferred.
So it takes no power to create the magnetic field around the coil?
It takes energy to create the magnetic field around a coil.  How quickly you create it, determines the power.
If you look at my diagram you will see that at 0.69τ (point B) the speed of energy flow (a.k.a. power) into the coil reaches its peak and starts decreasing afterwards, eventually reaching zero power and magnetic energy equal to ½*L*(V/R)2, at Tau >> 5
If it dose,then that should be added to your above answer.
No, because I was writing about the final current and the only thing you can tell from the final current is the power of the heater formed by the coil's windings.  You cannot determine the energy transferred to coil's magnetic field from the final current alone.
Spilled Fluids
Quote from: tinman on July 19, 2015, 09:44:59 AM
Do you know of equal and opposite forces?
If the electromagnet is applying a force on a iron bolt,then the iron bolt is applying an equal and opposite force against the electromagnet.
Now tell us why these forces should increase simply by replacing the iron bolt with a PM,without having to increase the energy applied to the coil?.If you cant answer that,i will answer it for you.
It's really quite simple; neither the PM nor the ferrite nor the bolt are doing any work, it is the electromagnet.
You obviously don't even understand your won experiment.
tinman
Quote from: Spilled Fluids on July 19, 2015, 09:57:45 AM
Ok guru,dose it take energy to create a magnetic field<--lets see if you can answer this.
Oh,by the way--the bricks in your car thing. Once the car is moving,the bricks now has stored potential energy. When you stop the car,the bricks would have given back that stored energy in way of inertial force against the car.
