0 Members and 80 Guests are viewing this topic.
MarkE
Quote from: synchro1 on July 19, 2015, 10:34:43 AM
@MarkE,
A laser beam is not an electrical current.
Pirhana are not elephants.
tinman
@ MarkE,PW,verpies-we wont include SF,as he just dosnt know.
My point is this.
We all agree that it takes energy to create a magnetic field<--right?
So with this being understood,i can give good reason as to how and why a PM can do useful work in regards to my experiment.It is all well and good to post fancy PDF's,and text book physics,but now it is time to deal with the real world,and we do this by experiments,as i have done.
In regard to my experiment that i gave SP to carry out(that he disagreed with,although being unable to tell us why). In order for the electromagnet to be attracted,a temporary field of opposite polls must be built around that ferrite keeper. As we know,to build or produce a magnetic field takes energy,and in this case,the energy is supplied by the electrical energy flowing into the coil to build that field around the ferrite keeper. When we change that ferrite keeper out for the PM,no energy is required to build that second field,as it already exist-->that second field is already built. So no energy is needed to temporarily align the magnetic domains within the keeper to create that temporary magnetic field,as it already exist with the PM. This is why a PM can do useful work,as it reduces the needed energy required to create that second magnetic field. No other material you use for the keeper will do this,as all will require energy to create that second field-->!!energy is required to create a magnetic field!!.
picowatt
Quote from: MarkE on July 19, 2015, 10:36:18 AM
So:  We all agree that no work is being done on the spring except when the magnet is initially energized, right?  So: Do we also agree that the input energy we want to measure is NOT during the static interval, but the initial interval when work is being performed on the spring?
If so, rate, time, inductance, resistance, reluctance, etc...
This simple experiment is getting awfully complicated.
We're gonna' need some fancy test equipment...
PW
tinman
Indeed.
And we can calculate the energy consumed,and the work that was done on the spring very accurately by using a capacitor of a set value,and with a set voltage,discharged across that coil in both circumstances--as i have done.I used an upside down L shaped pendulum to lift a set weight in stead of the spring. In every test,using many different materials as the keeper,the PM out performed all other materials by a margin of over 80% in calculated energy in regards to the height the weight was lifted.
synchro1
Quote from: MarkE on July 19, 2015, 10:37:24 AM
Farce. You went on to claim that the Laser generates an "Electrmagnetic field" a few comments back. With no help from electrons apparently? Lasers really have nothing what-so-ever to do with the subject of capacitor charge and are not even electricity.
