0 Members and 41 Guests are viewing this topic.
Above coil set wound like the image below, with 180-180 and 40 turns (ran out of wire for the "green" primary... guess it's time to prowl the back alleys again for discarded monitors. When's the next new moon again?)
tagor
Quote from: Cap-Z-ro on January 28, 2015, 10:54:18 PM
And...he says that after having just finished posting a phallic symbol, telling me to sit on it ???  Just how stupid does he think people are anyway ?  We know how stupid he thinks his arse kisser is though.
it is not a phallic symbol
it is a christmas tree
Now... here is something to think about. What happens if you have some energy stored in the magnetic field of a large inductance... and then you suddenly reduce that inductance to less than 1/10 its former value? Where does the energy go?
What if you do this over and over with some electronic switching magic?
John.K1
Ok , set-up No2 -Large ferite core ,2 magnets (from the Magnetron), pulsing coil same as yesterday. Technically if I good understand, the principle is in the change of saturation of the ferite?
Yes, I got some wild vibrations, but the range was between 7-9Hz and even more.  It was vibrating let's say for 15-20 s and then it got still for next 10s and slowly started again. I do believe the final effect mainly relay on the size of the core, material( it permeability) ,strength and the distance between the magnets (determining some mechanical resistance)  It was my last attempt and I am not gonna bother you anymore with this ;)
I want to ask you experienced guys for your opinion. On the next picture is my bench power-supply. I am not sure if is still in healthy condition after so many "things" happened  during the experimentation with HV devices ( namely Ruslans coils etc.).  When I use one channel ,under some conditions (like frequency in the circuit or the voltage increase)  it influence me the second channel. The output on the second channel just is all over the place and switching and so on. I do not remember this doing before. Could be something fried inside? I understand some EMF is going in to it. But shouldn't it be a bit resistant to these sort of things? Generally,I use one diode and ferite choke on the positive lead to give it some sort of protection. Any test suggestion to make sure it works fine?  Thanks.
