0 Members and 27 Guests are viewing this topic.
Pirate88179
Quote from: EMJunkie on September 28, 2015, 10:53:26 PM
Hahaha - Bill, your mentality is Classically Dufus Logic...
   Chris Sykes
       hyiq.org
Ah, your standard response whenever someone asks you for proof of any of your False Claims.  We expected no less.
At least you are consistent.
EMJunkie
Quote from: Pirate88179 on September 28, 2015, 11:38:57 PM
Which is almost exactly the same as 96 Watts from a "Dead AA Battery" - Bill you're so full of it, its just non-sense. the ultimate Sense of Hypocrite!!! Bill BS and Dufus Logic!!!
P.S: yours still officially Un-Invited! But here we are...
   Chris Sykes
       hyiq.org
tinman
Quote from: TinselKoala on September 28, 2015, 07:42:21 PM
Nope, that's not quite correct. The changing current in the primary coil causes the magnetic field contained in the toroid to vary in strength and direction. Why would you think this would not produce inductive coupling to a secondary coil... since it obviously does? And not by flux leakage either... which is how Syke's demonstration is working.
If there is no flux leakage from the core, then how is the primary coupled to the secondary?
We know we can place say ten turns on one side of a toroid, and then another ten on the other side of the toroid core, and when a current is passed through one, the other will couple to it. If there is no flux leakage from the core, then what magnetic field is causing a current flow in the secondary coil when a load is placed across it. ?
EMJunkie
Quote from: tinman on September 29, 2015, 01:24:04 AM
@Tinman,
I think you're getting Flux Linkage and Flux Leakage mixed up.
You are exactly right if you change the term to Linkage. Its just the one word that TK is trying to be picky about.
Flux Leakage, is more commonly known as "Leakage Flux" or "Loose Coupling" or "Loosely Coupled" device.
I have posted in the past, the document from George I Cohn "Electromagnetic Induction" is one of the best I have seen when it comes to this Field, Electromagnetism.
   Chris Sykes
       hyiq.org
forest
There is more insteresting experiment you can perform. Induction occur also if you make and break the magnetic path. :-) Obvious example is Leedscalning PMH.
