0 Members and 35 Guests are viewing this topic.
tinman
Quote from: Magluvin on September 29, 2015, 10:30:48 PM
Run a single wire through the hole of the core, exactly in the middle of the hole and it will be induced by the primary.
Mags
Mags
Indeed it will-->poynt99  ;)
This gives rise to the poynting vector,which is the cross section of both the primaries E field,and the secondaries B field.
poynt99
Mags
Yes, it will. Why? From flux cutting across the wire? No.
It's the E field produced by the changing flux in the core. The induced E field induces an emf in the wire.
The E field also induces an emf in the secondary in our example.
The E field is not confined to the toroid core, while the B field is.
EMJunkie
Quote from: tinman on October 02, 2015, 07:47:19 PM
@Tinman - Question for you - I believe this will be very important for all...
If you vary your Input Voltage, from 12 Volts, down 1 Volt at a time, and record the performance, do you see a drop off entirely of the efficiency?
I expect you will see a point where the RT is no longer as efficient.
In fact, I believe, by changing your input voltage you will be able to change the output efficiency.
If you need some assistance, I have attached a handy little Tool, I call it COP Calculator. Save the results to Image when done for a Quick record. See Below Image:
Zip File is attached: COP_Calculator.zip
   Chris Sykes
       hyiq.org
tinman
Quote from: poynt99 on October 02, 2015, 08:48:21 PM
QuoteThe E field also induces an emf in the secondary in our example.
It is actually an EM field,as the E field is changing in time. An E field on it's own will not induce an EMF in the secondary,as a pure E field is not changing with time-is static.
poynt99
There are electrostatic E fields (non-changing), and then there are non-electrostatic E fields which are induced from a changing B field. This is the type of E field we are dealing with in our example, and it is responsible for inducing an emf in the secondary.
So the E field I am referring to is not "on its own", it is the changing E field induced by the changing flux within the core.
