0 Members and 122 Guests are viewing this topic.
Quote from: EMJunkie on October 05, 2015, 06:10:18 AM
And the tool of OU.com pipes in...
What practical use is this post TK, are you just trying to upset Tinman?
Really, you should be ashamed of your Arrogance, its ridiculous!
   Chris Sykes
       hyiq.org
P.S: Here is a thought, how about trying to be Productive, Constructive and less Destructive!!!
How about getting FACTS correct? You are the one being arrogant and destructive, as well as being WRONG, Chris Sykes. Over and over again.
tinman
Quote from: poynt99 on October 05, 2015, 08:17:47 AM
QuoteAre you using a one to one transformer ratio?
Yes-all 3 windings are 1-1,the primary,secondary,and the third coil that is wound around the core with the primary all are 50 turns.
QuoteIf not, would you expect the phase differences between voltage and current to be the same in both the primary and the secondary?
In some transformers yes,and some no-->depends on configuration of the transformer.
QuoteHave you tried the same test on a commercial transformer? What were the results?
Yes,and once again,it depends on what type of transformer you use as to whether the current phases are in phase or out of phase.
forest
Some time ago I asked if anybody is able to measure when the output voltage on secondary is formed.I think it is formed right before current flows in primary immediately after the EMF applied to primary. Sure, nobody has access to such fast tools to test it...
gotoluc
EMJunkie
Quote from: TinselKoala on October 05, 2015, 02:10:37 AM
What are the units of the E field?
What kind of field surrounds the top terminal of a Van De Graaff machine?
   Chris Sykes
       hyiq.org
Quote from: TinselKoala on October 05, 2015, 09:23:02 AM
Here is my point:
Quote from: TinselKoala on October 05, 2015, 09:18:29 AM
Wrong, twice.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elefie.html
https://en.wikipedia.org/wiki/Electric_field
http://www.physicsclassroom.com/class/estatics/Lesson-4/Electric-Field-Intensity
The units of the E-field are _volts per meter_, or to put it another way, _newtons per coulomb_. Current describes the movement of charge, but the E field does not depend on movement of charge. Stationary charges produce an electric field. You can argue that charge has to move for it to be concentrated onto, say, the top of the VDG machine, but it is not the _movement_ of charge that produces the field, as I believe you have stated.
In fact if you look at the Hyperphysics link you will see this: "The electric field can be defined as the electromagnetic force per unit charge _in the rest frame of the charge_." (emphasis mine).
Also, you are using _wirewound_ resistors that have considerable inductance in your measurements, according to that photo from a while back. Plus you have the length of the probe ground clipleads as well. How much of the current _phase shift_ in your scopeshots is due to the inductance of your measurement system, rather than your actual device under test? You don't know, do you?
You're unbelievable TK, unbelievable!!!
What is wrong with you? Do you have to prove your Arrogance to everyone here all the time, we already know how you operate!
Go back to your hole and don't come back! Tell Homeland Security you failed because you're so see through! Everyone knows how you guys operate, sticking out like a sore thumb!!!
   Chris Sykes
       hyiq.org
