0 Members and 185 Guests are viewing this topic.
EMJunkie
Quote from: MileHigh on November 01, 2015, 04:16:51 PM
You are already in a deep hole, keep on digging.
The only Hole I have dug, Milehigh, is for you old Mate!
I am not in it, at all, it is you, your errors, and your assumptions, lack of understanding, lack of willingness to understand, and also your Arrogance toward others here.
Sink or swim, it is up to you.
So many people do great work, they deserve all the credit for what they do. A little old bloke with a bad attitude will not stop the masses!!! Especially when someone here keeps proving him to be Wrong!
   Chris Sykes
       hyiq.org
partzman
Quote from: MileHigh on November 01, 2015, 02:34:03 PM
Partzman:
Unfortunately, what you've got going is a unfortunate mix of decent knowledge and self-delusion and hubris.  All that you have to do is apply yourself and get more serious and your magic over unity COPs will evaporate into nothingness.
I am not up to walking you through a circuit analysis and discovering your errors, but I can assure you that they are there.  It's just like the negative resistance conclusion for Tinman's circuit, it's just another failure to look at everything with a critical eye and double check and triple check everything.
Even though I am not up to doing this kind of circuit analysis anymore, I do know electronics and I know when someone is deluding themselves.  You should take my advice and put all of your conclusions in check.  For example, if you simulate your circuits with pSpice and drop power monitoring probes in the circuit, you are not going to find over unity.   Then you can use the pSpice simulation to help you find out where you went wrong.
MH,
First let me state that I have not been able to simulate these types of circuits successfully.  I mean they not only produce COP<1, but they don't replicate the wave forms and phasing correctly. IMO, this is due to inaccurate modeling of the transformer topologies.
Now, before you jump to conclusions from that statement, let me state that I have successfully modeled circuits including non-linear transformers using the Chan model, non-linear solar cells/panels, various and sundry parametric devices including non-linear mosfet capacitances, etc, so I consider myself somewhat capable using simulations.
Regarding my self-delusions, etc, I am always more than willing to have my mistakes pointed out to me whether it be by you or anyone else. I may not like it but I will admit my mistakes because after all, I'm just a 74 year old high school drop out so what do I know!
One more thing and this may upset some here, but don't spend too much time trying to analyze the circuit diagram for it is not completely accurate. However, the waveforms are. If anyone wishes to do any circuit analysis or attempt replication, PM me.
partzman
EMJunkie
Quote from: partzman on November 01, 2015, 04:56:59 PM
MH,
partzman
@Partzman - I will do a replication of your Circuit.
I am certainly not one to shy away from something, not afraid of a little hard work! I know others here will pick at every little thing they possibly can pick at, to try to discredit what in the end can not be discredited. But I am up for it!
   Chris Sykes
       hyiq.org
P.S: It seems it is very similar to another circuit I have replicated?
Interesting read on Page 8 about this Configuration
tinman
Partzman:
QuoteIt's just like the negative resistance conclusion for Tinman's circuit, it's just another failure to look at everything with a critical eye and double check and triple check everything.
Will you be so quick to dismiss Smudge's findings also ?.
partzman
Thanks to all of you expressing an interest in replicating my circuit. I have decided to disclose the correct info which is in the attached pdf below. It is embarrassing to admit but it was an honest documentation mistake on my part due to the many circuits I work with over the course of time.  The circuit originally shown does work as well but only at frequencies in the 1-3Mhz range utilizing the same coil arrangement with different component values.
I used 15x34 litz as I have it on hand and split it into 7x34 and 8x34 windings for L1 and l2. The object of this construction is to obtain a high inter-winding distributed capacitance and inductance so other winding arrangements should work if they meet this criteria.
One thing I will add, a FG can be used to drive the circuit with a sine wave and although the power output will be lower, there will still be gain observed.
If you have questions, ask.
partzman
