0 Members and 91 Guests are viewing this topic.
seychelles
The way i see it the A-B COIL IS THE PRIMARY AND THE OTHER COIL IS THE SECONDARY
PICK UP COIL.
tinman
Quote from: seychelles on November 12, 2015, 06:26:01 PM
PICK UP COIL.
It clearly show's that the bottom center coil is marked as primary.
If the A B coils were the primary,then yes,an EMF would be produced in the single center coil(marked as the primary)coil.
tinman
Quote from: EMJunkie on November 12, 2015, 06:23:38 PM
Hi Tinman,
Turns Ratio needs to be approximately 1:3 - Primary:Secondary
Be careful, this setup can very easily damage your equipment!
   Chris Sykes
       hyiq.org
Mains frequency im guessing ?.
citfta
seychelles
yep i can see, but if one instead of using ac use dc pulse at a high
frequency that is when one will see this working more efficiently.
the reason if a-b is input then the the emf is doubled in the inside
core which the output coil should be. I WILL PUT A VIDEO OF MY
FIGAMAGIC ON UTUBE SOON .OPPOSING MAGNETIC FIELD DOUBLE THE
OUT PUT ALWAYS.
