0 Members and 40 Guests are viewing this topic.
Pirate88179
Synchro1:
I have glued two neos together such that the like poles were attached to each other.  All I got from that was a thicker magnet with a N and S pole.
Now, I did not wind it with wire or anything like the experiment that you posted, but I am just wondering why that might work when the magnets become like one larger magnet?  Is there something "special" at the joint that i could not see or detect?  ( I just checked for poles)
Have you tired this experiment?  If so, what happened?
It looks easy and cheap enough to do, i might give it a go.
synchro1
Quote from: Pirate88179 on January 30, 2015, 10:57:14 PM
Synchro1:
@Pirate88179,
You need to use ceramic magnets. I never tried this one.
Quote from: synchro1 on January 30, 2015, 10:23:16 PM
I came across this experiment on "Bucking Magnet Fields" and "Scaler Waves". I found it interesting because it demonstrates that Scaler Waves are emitted from the joint between the magnet faces at certain frequencies. This caused me to reflect on the Jerry Bayles spinning "Chiral Disk" magnet tests. (Chiral=Bucking). The experimenter's lighting a "Zenon tube" just exciting the magnet windings with that DC motor!
        _______
      |  \   \ _______\ S
       \   \  |       |      Obtain two Radio Shack ceramic magnets and
         \   \|_______| N    glue their north pole faces together.
           \  |       | N
             \|_______|
                        S
            _______          Wind the magnets with about 50 turns
          |\   \\\  \        of #30 magnet wire.  Wire gauge is not
          |  \  \\\\  \      critical.
          |  \   \ _\\\\__\
             \   \|__||||_|
                 \|__||||_|
                     \  |      ________
                     |  |     [ small, ]
                     |   -----[ noisy  ]----------o
                     |        [_motor__]           6v to 12v power supply
                     |____________________________o
The brush noise from the DC motor provides a pulse signal to the coil,
which modulates the 'colliding' field pattern of the magnets and creates
interesting scalar effects within a narrow pencil-beam pattern which extends
from each face of the magnet out to a few inches.
            _______
  <<<<<<<<<<<\   \ _\\\\__\>>>>>>>>>>>>>>>>>>>> scalar effect comes from the
  <<<<<<<<<<<<<\  |  |||| |>>>>>>>>>>>>>>>>>>>>> joint between magnet faces
             \   \|__||||_|
                 \|__||||_|
I tried that one a long time ago, 15 years or more. I even had the motor spinning the magnet assembly on its long axis in one version. This was supposed to influence plant growth, as I recall.
In the example you cite, the xenon flashtube is being flashed by ordinary inductive collapse spikes, nothing more. Xenon is actually highly conductive at low pressures.
Now, if someone can make the xenon tube flash without it being connected by wires to the coil, just by "beaming the scalar waves" at it ... please let me know right away.
Magluvin
Never got the scalar wave deal.  Is it a beaming of a wave?
In audio, did car audio for 20 yrs,  if the wavelength(or half wave length, have to look that up again) of the output of the driver is smaller than the diameter of the driver ( speaker, tweeter, sub) diaphragm, there is a beaming effect rather than an omnidirectional propagation.  Like around 3khz, the wavelength is around 6in. So if you have a tweeter and mid with 3k input, if you change the distance of the tweeter closer to you in reference to the mid driver, the sound will cancel out. Bring the tweeter 6in closer, 12in in ref to the mid driver, the sound is back in phase.  Can make a system sound bad by putting tweeters high on a door panel if the distance offset is off.  Some guys out there can tell the difference, by listening, of the tweeter is equal distant from the listener, or if it was 12in closer yet still in phase. Odd things happen in that delay around the crossover freq and is detectable by a critical ear.
So the 6in speakers are generally cut off at around 3khz, and say an 8in would be at a lower freq, that is if the company that makes the item cares about those things.
Bah, went off a bit there.
Mags
