0 Members and 111 Guests are viewing this topic.
tinman
Quote from: EMJunkie on November 29, 2015, 01:32:39 AM
Will do you a deal Tinman - I will share some more data. How about you make it so that others out there get a bit more info on the RT?
   Chris Sykes
       hyiq.org
No deal EMJ.
It was clearly stated and agreed to that i would share only measurements taken as instructed-which i did. I also have given out more than i was going to. I need to go about the RT in a different way,as the first try didnt go so well. But it will be back,although not quite in the same form. There was a solid state version under way,but that came to an abrupt end,and i do have people trying to figure out where to go from that point. Thats about as far as i can go into it ATM. The problem with the RT is the noise and the brushes only lasting about 5 weeks. So there is two options--1,we try and design a brushless model,or 2-we go solid state. Either way,there is not a lot i can do at the moment.
EMJunkie
Quote from: tinman on November 29, 2015, 08:26:52 AM
No deal EMJ.
Fair enough, you have your reasons.
Like me, you have spent thousands of hours, ton's of dedication learning what works and what does not, and no doubt lots of money.
Of all, the Learning is the most important!
The lost Family time can never be regained but it is them we do it for!
   Chris Sykes
       hyiq.org
EMJunkie
We all know how a Speaker works?
Magnetic Flux is directed via the Magnetic Keeper so it is at 90 degrees to the Coil Conductor, when the Coil Conductor is energized with the Signals from the Amp there is a Maximum Force exerted on the Magnetic Field from the Coil Conductor in the direction governed by the flow of Current.
Below is an Image, a Cutaway of a Speaker:
   Chris Sykes
       hyiq.org
EMJunkie
It is also the case that a Maximum EMF is also induced when the Magnetic Flux is moving with Velocity v at right angles, 90 Degrees, to a Coil Conductor!
This is the Flux Cutting Law: Bvl
Where:
B = Magnetic Field Density
v = Velocity
l = Length of the Conductor exposed.
   Chris Sykes
       hyiq.org
EMJunkie
We know two very important things from this!
1: Maximum Force is exerted on a Magnetic Field when it is Directed at Right Angles to a Coil Conductor carrying a Current.
2: Maximum EMF is also Induced in a Conductor when the Magnetic Field is moving with Velocity v at Right Angles to the said Conductor.
This does not include the Flux Linking Law's!
So why am I reiterating this information again, in a different way? I am sure you can see why?
   Chris Sykes
       hyiq.org
EDIT: To avoid confusion, this is not related with: Post: 466953 above.
