0 Members and 81 Guests are viewing this topic.
EMJunkie
I think the absolute most important thing in all this work is simply: having a goal to aim for - Not having to work blindly, stumbling through attempt after attempt and getting no where...
I am firm in the belief that this is what I have provided with an absolute wealth of supporting evidence - Please correct me if I am wrong!
Partnered Output Coils are the best way to achieve the goal, Free Energy! It has not been done before, to my knowledge, no one has picked up on this and publicly shared this information. A few have shown the concepts behind this Tech and talked in a very brief bit about it.
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: digitalindustry on December 05, 2015, 09:58:45 PM
to me it depends on what you mean by the word:
"flowing'
if you pass a 'voltage' into an inductor you induce a magnetic field, if this goes from 0 to X then you could say that the flux is 'flowing'
but what i thought you meant was that you have to pulsate magnetic flux though the coils at A freq say (Freq Y) etc?
is this what you are saying?
i.e you can use pulsating 'DC' or 'AC' rectified or natural 'AC' (I call it rotating) at certain freq but not 'DC' (i call it non rotating)
what we are calling 'AC' is a 'rotating mag flux.' so maybe we should rename it 'RmF' in future.
i'll be honest with you i don't know what a 'Volt' and a 'unit of current' really is, except the vectors of a 3D pulse of magnetic field.
maybe best understood as 'spacial' and 'counter spacial' like the vortex in a magnet out from the center field.
as stated by the writer of 'hidden secrets of magnetism' you can cut a magnet infinity amount of times and the center of this field will always balance.
Summary (sorry for rambling)
I think you are saying there has to be a fluctuating mag field in the opposing inductors so that the fields create a disturbance.
next issue would be at what freq.
A good relevant example might be Tinman's HHO
i think that the cap is charging and then firing the spark this causes the cap to discharge the field, the coil is shorted then un-shorted right?
however this is really and on/off effect (as i see it) at the point of spark the coil is 'shorted' through the Cap but the cap discharges the field in the HV coil collapses and pulses the primary coil.
so to relate that to your statement, when the spark was not induced there was a 'current flowing' but only at the freq and amplitude of the motor when the spark started to modulate the 'current flow' the HHO also started to 'flow'
: D
@Digital - The end bit is right, in the middle not so much.
A Voltage is applied across a Coil. Normally Switched in across an Inductor.
The Current will ramp up over time, this can be calculated. A Current (Charges Moving or Flowing) moves through the Conducting Wire in the Coil. As this flow is ramping up over Time, the Magnetic Field also Ramps up over Time. See my pdf document I go into this in some detail.
The Magnetic Field is the Current Flow, they are equivalents, Magnetic Field and Current (Moving Charges)!
See Nikola Tesla's Egg of Columbus to see exactly what a Rotating Magnetic Field is. Of course this is how the Electric Motor works. Perhaps the greatest invention of Nikola Tesla that is in common use today...
   Chris Sykes
       hyiq.org
digitalindustry
Quote from: EMJunkie on December 05, 2015, 10:02:19 PM
   Chris Sykes
       hyiq.org
is not the image above not a 'partnered' coil?
if we look carefully at it.
the primary is fluctuating via the Cap spark gap - and inducing the same basic effect as in TM HHO design, but look at the secondaries.
this is where the 'power' is to come from, that is a partnered coil system is it not?
in this case there is an 'air core' and no permanent magnets but the systems seems viable to me as proven by Tinmans video there.
EMJunkie
Quote from: digitalindustry on December 05, 2015, 10:25:33 PM
I think you have answered your questions there Digital!
   Chris Sykes
       hyiq.org
digitalindustry
one more time for the forum:
if you watch Tinmans HHO video -
https://www.youtube.com/watch?v=ZyW4dR4cUQM
and then look at the image of the 'Don smith system'
you might find that there are 3 key things 'tuning' the freq of the Primary in the image:
- the Variac
- The cap
and
- The spark gap
this is all in the objective to make that primary pulse at a certain freq.
the viraic is adjusted for the spark gap efficiency, the cap is adjusted for the speed to fire.
then after that the Primary mag field effects strongly the 'partnered coil' system on the secondary.
this seems viable to me.
