0 Members and 101 Guests are viewing this topic.
EMJunkie
Quote from: EMJunkie on September 24, 2015, 07:01:01 PM
This video is very good to see the Magnetic A Vector Potential: https://www.youtube.com/watch?v=2_hwGahuDRE
This person needs to be commended! Good work!!!
Also: https://www.youtube.com/watch?v=2QCt7ZbNQAU
   Chris Sykes
       hyiq.org
Credit to: http://www.enigmatic-consulting.com/Communications_articles/EnMnofields/No_time.html for Images
@Tinman - I believe this, the above quoted Post will help in showing what is going on in your Magnetic and electric fields of a coil test Videos.
For ease, I have reposted the Image again. Looking at the Magnetic Curl at the ends of the Inductor (Primary) should explain the Voltage differences. I believe you're right about the Capacitive Coupling causing the Phase Angle difference.
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: EMJunkie on September 13, 2015, 07:52:03 PM
P.S: Why is Three the Magic Number? Action, Reaction and Counter-Reaction... Newton's Laws of Motion...
People, if you want to progress, I recommend thinking along these lines, quote above. Imagine the Electron in the wire as a Soccer Ball, we want to Kick it once and then use its very own motion in the forward direction, to reduce all losses trying to stop it moving forward.
Normally, we only see: Action, Reaction
Floyd Sweet told us the same thing:
As the load on the machine increases, the volt-ampere product increases. The rate of flow of charges increases. Quantum mechanics state not all electrons in copper are free to carry charges. Then it's time to set the wheels in motion to free them from binding magnetic forces. Once this is done, conductivity will improve and resistance decrease as we are dealing only with electrons. Copper will not change to another metal as atoms which are mostly empty space would have many electrons to spare anyway.
   Chris Sykes
        hyiq.org
digitalindustry
stivep
thanks for all the info i will go though all of it.
The only point is i did not say the frequency was 'delivered' to the capacitor i said the frequency was 'derived' = resulted from.
and i'm talking specifically about the collapse frequency, which is triggering the magnetic field for the secondary (as in similar case of  TM video)
this is derived=resulting from, the V peak to the spark gap the Cap and the 'Variac' (which is controlling the 'pressure')
i was highlighting the parallel between TM own ingenious design and that system and the 'partnered coil'
Just read it all - Re the pic i have no level on here no level to speak of ha ha.
every entity has a complex level that is ultimately unimportant except that we can learn from each.
certainly no need to wear a lvl on your sleeve ha ha
feel free to share anything you think is significant.
digitalindustry
Quote from: EMJunkie on December 06, 2015, 08:10:03 PM
   Chris Sykes
        hyiq.org
I agree, however if the 'electron' exists at all i'm fairly certain it is not a particle.
however it's splitting hairs i guess in this case.
however symbols are important to humans i fully well expect that people that believe they know what a 'volt' and a 'unit of current' is understand the measurement symbol and some of it's relationships but don't know what it is really measuring?
if anyone is confident they know, please educate me.
digitalindustry
Quote from: PIH123 on December 06, 2015, 05:06:06 PM
I would like to reiterate what Chris has said above using his own words.
Post 274 on page 19 (over 400 pages back BTW)
http://overunity.com/15395/partnered-output-coils-free-energy/msg434894/#msg434894
One of Ten Devices may work as I have said
So make sure you go into this with the mindset that, even if you follow the specs to the letter,
you have only a 1 in 10 chance of it working.
But Good Luck all
Pete
this tells me we perhaps shouldn't be just following specs, instead perhaps we should be doing more like what TM Luc and others are doing and building things to learn and understand.
after all we aren't dealing with 'voodoo' or as some other guy said 'white mans magic' ha ha the universe has rules, blind faith and luck should only be used as an opportunity to learn something.
otherwise what is the point?
