0 Members and 72 Guests are viewing this topic.
wistiti
The best way is to build it and test it!
and then try to improve it... :)
ps: i think all the credit go to you Chris; it is you how bring it to us.
EMJunkie
Quote from: wistiti on December 10, 2015, 08:53:39 AM
Thanks Wistiti,
You're right my friend, the only way is to build and to prove it. Thay also said the same:
Quote from: Thaelin on December 09, 2015, 02:16:31 AM
Yuri did what I did, and got the same results. It baffels you to see it.
Even worse, is when you try to prove yourself wrong and the results
hold rigid.
Now lets see how bad the pack tears this one up.
We know the potential here and have worked on this for some time now. We know it takes a little work sometimes, not every machine will be a winner, but it does work and its the absolute most simple way to achieve a result I have ever seen in my entire Research! By far the Cheapest and Simplest!!!
How much proof does one need before a potential can be seen? Maybe Belief is just to over powering for some people!
The Wistiti Partnered Output Coil Toroid (The Wistiti POC Toroid) is Genius!!!
   Chris Sykes
       hyiq.org
EMJunkie
A Solid State Electrical "Generator" all from a three Coils. Working from the Magnetic Force, observed as the Inverse Square Law. Faradays Law of Induction!
The Hydraulic Ram Pump, self sustaining because of the Inverse Square Law:
In physics, an inverse-square law is any physical law stating that a specified physical quantity or intensity is inversely proportional to the square of the distance from the source of that physical quantity.
   Chris Sykes
       hyiq.org
EMJunkie
This Video showing the Concepts: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation - Published on Jul 18, 2011
The Increase in Light when the Self Assisted Oscillation Coils are connected at no cost on the Input!
"On rare occasions, Sweet saw this effect, called self-oscillation, occur in electric transformers"
Ref: http://merlib.org/node/5282
"Sweet was also a transformer designer and expert, and he remarked that he had also observed specialized self-oscillation in certain transformers."
Ref: Energy From The Vacuum by Tom Bearden
Also See: Tom Bearden - On Floyd Sweet was a Transformer Specialist
   Chris Sykes
       hyiq.org
EMJunkie
I realise that everyone has their own Path, but I ask you, please don't pass this by, this is of great significance!
This will change the world!
Change our future!
   Chris Sykes
       hyiq.org
