0 Members and 91 Guests are viewing this topic.
EMJunkie
The reason that Over-Unity is possible, is simply: Faradays Law's of Induction
Partnered Output Coils: Anti-Lenz effect - from: Юрий Лиховид (Yuri Likhovid)
   Chris Sykes
       hyiq.org
EMJunkie
This Video showing the Concepts: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation - Published on Jul 18, 2011
The Increase in Light when the Self Assisted Oscillation Coils are connected at no cost on the Input!
"On rare occasions, Sweet saw this effect, called self-oscillation, occur in electric transformers"
Ref: http://merlib.org/node/5282
"Sweet was also a transformer designer and expert, and he remarked that he had also observed specialized self-oscillation in certain transformers."
Ref: Energy From The Vacuum by Tom Bearden
Also See: Tom Bearden - On Floyd Sweet was a Transformer Specialist
   Chris Sykes
       hyiq.org
ENERGY is not measured in WATTS. Power is not energy. The fact that the meters say "ENERGY" but are reporting a figure called "WATTS" should be telling you something. And earlier in that video we can see a very brief reading of Power Factor on one of the meters. What does a correction for Power Factor do to the readings? Are the readings shown corrected for PF, or not? It is not possible to tell from the video.
Bad measurements using bad meters do not support claims of overunity performance. Show me some measurements made with an accurate, laboratory-grade Power Analyzer. Of course you cannot, and no OU claimant will do so either, since such _properly performed_ measurements will not show "overunity".
EMJunkie
Quote from: TinselKoala on December 13, 2015, 12:42:44 AM
TK, surely you have to agree that these meters are reasonably accurate, there are standards, at least here in Australia, that govern these things: NMI M 6-1 - Electricity Meters - Part 1: Metrological and Technical Requirements
I am sure this is the case in most developed Countries.
We know Energy is Joules, which is what the Watt is derived from: Joules per Second
The watt (symbol: W) is a derived unit of power in the International System of Units (SI), named after the Scottish engineer James Watt (1736–1819). The unit is defined as joule per second[1] and can be used to express the rate of energy conversion or transfer with respect to time.
If this device and others out there, already replicated and tested to also show Over-Unity performance are dismissed because of the POSSIBLE error in measurement on these meters then the entire Electrical Engineering Field is not measuring power properly.
I can assure you the output is a pure sine wave unless Core saturation is reached. All at low Frequency.
Lets agree, Some 100+ Watts is a massive measurement Error!!!
   Chris Sykes
       hyiq.org
minnie
   Yes Junkie,
             100 watts is a massive amount. With modern technology that is enough
to self loop!
      Then you would have a perpetual motion machine and end up as one of the
most famous individuals ever!!!!
                   John.
