0 Members and 90 Guests are viewing this topic.
seychelles
This can easily be proven like when JEAN LOUIS NAUDIN was testing the
GENENE USING AN INDUCTION COOKTOP.. The most accurate compound
to test with is distill water . One litre  of distill water takes so many watts , joules
what ever you want to call it to heat it up from X degrees to Y DEGREES IN SO MANY MINUTES..
SO TK WE DO NOT NEED A LABORATORY AND A BUNCH OF NASA ENGINEERS  TO FIGURE THAT OUT
DO WE..DO THE TEST WITH STRAIGHT 240V WITH AN ORDINARY KETTLE THEN MONITOR THE WHAT EVER YOU
WANT TO MONITOR . THEN SAME VIA THE TRANSFORMER.. EVEN A WACKO DUMBO FROM SEYCHELLES CAN FIGURE THAT
OUT.. KEEP IT SIMPLE GUYS.. OTHERWISE THE BOOKIMAN WILL LAUGH AT US..
EMJunkie
Quote from: minnie on December 13, 2015, 04:20:07 AM
   Yes Junkie,
             100 watts is a massive amount. With modern technology that is enough
to self loop!
      Then you would have a perpetual motion machine and end up as one of the
most famous individuals ever!!!!
                   John.
John, I am sure even you can manage a build on this very simple device!!! Then you can "Self Loop" as much as you like!!!
Surely you have a 110 Volt Toroidal Transformer with 24v 24v outputs on it? TK will no doubt help you with your new Scope!
I prefer to not use the term "Perpetual Motion Machine", it sounds too much like the Atom that can exist indefinitely under the right circumstances and that's just something we will never be able to achieve! Friction, Wear... To many factors for Eternity!!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: seychelles on December 13, 2015, 04:36:22 AM
@Seychelles - Exactly Right!
Simple as possible, don't over complicate anything! It is all very simple! Its a simple build! Its not complicated!
Please: Fuse it don't Loose it!
Lets not forget, these are Mains Frequency's! Using Mains Power Metering Equipment!!! Mains Voltages, so be careful!
This device (The Wistiti Partnered Output Coil Toroid) has been replicated at least 4 times I know of. It works!
   Chris Sykes
       hyiq.org
EMJunkie
I have already explained where the Excess Energy comes from: Faradays Law of Induction.
Excess Charges are broken free of their binding forces... Sound familiar? Induction, the Coils Interact together in such a way that Induction moves toward a Super Charged State and The Load Current is regulating this Super Charged State. In some situations at least...
If you like, its Induction on Steroids!
This is not an inexorable process, so don't panic.
   Chris Sykes
       hyiq.org
EMJunkie
Induction is not a monadic process, its not 1:1 or < 1.
It can be stimulated, it can be revivifying process, not a degenerative process.
   Chris Sykes
       hyiq.org
