ramset
Well
to be honest ,I do not like that one bit...
but to be honest ,Honest...Not really
crazy about Hide and seek either.
and to be absolutely clear Over unity research
is no place to make a claim and not back it up
with good measurements , actually a very bad idea
in most places that you would ask people to replicate.
    Even a black box Demmo showing your equipment and
all the connections as well as provisions you made to insure
no extra energy could enter the system leading to
false readings and claims [Happens ALL THE TIME ]
so the next few days will show just what has
gone on with this.
and in the mean Time Cyril [Smudge]has brought
some ideas forth to experiment with which fall in
line with experiments HE has performed in the past
as well as Work HE has been involved with .
that will be very interesting to see and there will most
likely be a thread here too.
Chet
Thanks Grandma
synchro1
Here's where the tests should be directed:
"Proof that free energy is obtained through wobbulation around the axis of a spinning magnet where the wobbulation is 90 degrees to the magnetic field. The result is a changing energy field axial within a hollow pickup coil that is 90 degrees to the magnetic field but inline axially to the wobbulation offset. A coaxial capacitor in the coil is used to pick up the radial electric field and the presence of that field proves the concept of a three dimensional 90 degree field change which is accomplished via the action of the spinning magnet wobbulation towards the pickup coil"
https://www.youtube.com/watch?v=TnSAfL7z7go&feature=youtu.be
ramset
Fix that mess please ..chop every half dozen words so it stays in one frame!
I'm getting dizzy running back and forth.
as a matter of fact I'm leaving this thread alone
you want to discuss YOUR experiment start
another thread and share YOUR results.
you want to fight with MH Start a steelcage thread.
I will not post another word here,fellows are spending
Their time and money Here...I respect that.
Chet
Thanks Grandma
conradelektro
I think the best is to just not answer the postings of Mr. synchro1. An attention seeker will be disappointed once he gets no reply. That works with children and should therefore be the right treatment of a never-grown-up.
Greetings, Conrad
conradelektro
I did a test with the coil as a "normal transformer". Please see the attached drawing.
Only secondary H2 (of the pair H2 + H3) is connected in parallel to the resistor R2, primary H1 is wound over H2:
10 Vpp sine wave from function generator, 2 khZ
Vh = 0.28 V
Vt = 2.44 V
Vr = 2.44 - 0.28 = 2.16 V
I = 2.44 / 100 = 0.024
Ɵ = 5°
Watt through the primary H1 (input) = 0.024 * 0.28 * cos(5°) = 6.7 mW
V0 = 0.68
Io = 0.68 / 100 = 0.0068
Watt through R2 (output) = 0.68 * 0.0068 = 4.6 mW
Result: input of 6.7 mW through primary H1 results in an output from H2 through R2 of 4.6 mW
One can do the same measurement and calculation with R2 in parallel with H3:
Vh = 0.33 V
Vt = 2.44 V
Vr = 2.44 - 0.33 = 2.11 V
I = 2.11 / 100 = 0.021
Ɵ = 25°
Watt through the primary H1 (input) = 0.021 * 0.33 * cos(25°) = 6.3 mW
V0 = 0.72
Io = 0.72 / 100 = 0.0072
Watt through R2 (output) = 0.72 * 0.0072 = 5.1 mW
Result: input of 6.3 mW through primary H1 results in an output from H3 through R2 of 5.1 mW
Greetings, Conrad
