0 Members and 53 Guests are viewing this topic.
EMJunkie
I talk about Induction, but for those not in the know, there are some Rules to Electromagnetic Induction:
1: Time Rate of Change - This is the Frequency. (Either the Change of the Magnetic Field, or the Conductor, sometimes both) Normally referred to as dt or v, Velocity.
2: Magnetic Field Strength - Normally referred to as B, Gauss. (10,000 Gauss = 1 Tesla)
3: Turns - Represented by N in the Below equations. See pdf.
4: CSA (Cross Sectional Area) - The size of the Coil in the Horizontal Plane. Sometimes referred to as l (Length)
5: Wire Size (AWG) - this one is very rarely referred to - Determines the output Current carrying Capability. Ohms Law.
Normally, bigger is better for all of these factors. See George I. Cohn pdf attached.
   Chris Sykes
       hyiq.org
EMJunkie
From the King of Stray Inductance: some embarrassing behaviour there!!!
1: https://www.youtube.com/watch?v=hBPJFgq7Eyw
2: https://www.youtube.com/watch?v=w60ycUsuPIY&ebc
3: https://www.youtube.com/watch?v=tMiXAgDWpbk
4: https://www.youtube.com/watch?v=U3TMCYc3LNQ
When these magnetic fields are created, they can produce an inductive effect. Thus, wires or components leads can act as inductors if they are long enough. Such effects are often present within circuits (for example, between conductive runs of wire traces or components with long leads such as capacitors), even though they are not intended. This unintended inductance is referred to as stray inductance, and it can result in a disruption of normal current flow within a circuit.
Parasitic Element <<<--- a form of Subliminal Conditioning?
Parasitic definition
of, relating to, or characteristic of parasites.
2. (of diseases) due to parasites.
3. Phonetics. excrescent (def 2).
   Chris Sykes
       hyiq.org
EMJunkie
Again, I have said before, what I am sharing is not new! Much of this is very well known in Electronics: I give you an example in the below Picture!
This, Partnered Output Coils is Over Unity!!! - Partnered Output Coils are a Solid State Electrical Generator (I have gone through all this in prior posts)
It does take a bit of work to get there. I have given you all the information you need to get started. Videos showing effects! Documents with many pages of information and over a year spent here sharing information!
I have said before: "The Free Energy Future, Here Now! Now its up to You!!!"
It really is! This is so simple once you read and absorb the data I have presented!
Electromagnetic Induction is simple! Lenz's Law is Simple!!!
   Chris Sykes
       hyiq.org
EMJunkie
Real Current(I) and real Voltage (V) - Real Watts (W) - Real Energy (Joules per-Second) - the same as in the Conventional Electrical Generator via the 187 Year old Electromagnetic Induction that Michael Faraday discovered!
No magic, no Voo Doo Mystical HuHaa!!!
   Chris Sykes
       hyiq.org
EMJunkie
Partnered Output Coils work on all the same principles as Electromagnetic Induction:
Quote from: EMJunkie on March 04, 2016, 05:01:55 PM
   Chris Sykes
       hyiq.org
