0 Members and 183 Guests are viewing this topic.
EMJunkie
It can be read from the Horses Mouth:
FIELD SUPER-POSITION AND THE VACUUM TRIODE
Electromagnetic induction with no measurable magnetic field is not new. It is well known that in the space surrounding a properly wound toroidal coil there is no magnetic field. This is due to the superposition of the fields. However, when alternating current is surging through a transformer an electric field surrounds it. When we apply the principle of superposition to the vacuum triode it becomes more obvious how the device is in fact operating.
The principle of superposition states that; "In order to calculate the resultant intensity of superimposed fields, each field must be dealt with individually as though the other were not present". The resultant is obtained by vector addition of each field considered singularly.
Consider for a moment the construction of the triode which includes the bifilar coils located within the fields of the two conditioned magnets.
When the current in one half of the conductors in the coils (i.e., one of the bifilar elements in each coil) of the device is moving up, both the current and the magnetic field follow the right-hand rule.
The resultant motional E-field would be vertical to both and inwardly directed.
At the same time the current in the other half of the conductors in the coils is moving down and both the current and magnetic field follow the right-hand rule.
The resulting motion E-field is again vertical to both and inwardly directed.
Thus, the resultant field intensity is double the intensity attributable to either one of the set of coil conductors taken singularly.
The first term B x V in the equation represents the flow of the magnetic field when the electrons are moving in one direction, while the second term Negative B x Negative V defines the flow of the magnetic field when the electrons are moving in the other direction. These measurements indicate that field intensity is directly proportional to the square of the current required by the load placed on the device.
By now, you, who have followed this thread, should know exactly what this means!!!
   Chris Sykes
       hyiq.org
EMJunkie
or:
   Chris Sykes
       hyiq.org
P.S: Wistiti, your next post, I have replied via PM. Thank You my friend!!!
wistiti
Thank you Chris!
You bring so much to us...
EMJunkie
Quote from: wistiti on March 25, 2016, 08:42:25 PM
Thank you Chris!
Thank You Wistiti!
Forest bought this up, and you found an image that is similar to the one I was looking for: http://www.free-energy-info.co.uk/Chapter22.pdf
The Image attached below:
   Chris Sykes
       hyiq.org
EMJunkie
In reading around different forums and looking at others excellent work, it seems that many are getting stuck on the same point: Not being able to make Bucking Coils, or Partnered Output Coils work
This means there is: No Current Flowing in the Partnered Output Coils!
Remember, the Magnetic Field is: B = µNI/L
Where:
B = The Magnetic Field in Gauss
µ = The Permeability of your Core.
N = The Number of Turns of your Coil
I = Current in the Coils
L = The Length of the Coils.
To put this plainly:
Quote from: Guidelines To Bucking Coils URL: http://www.hyiq.org/downloads/guidelines%20to%20Bucking%20Coils.pdf
Note: Importantly, for this device to work, Current must be flowing in the Partnered Output Coils!
I have shown many ways to get the Current Flowing, the easiest way is simply Via Electrical Connection: See Below Image, the second way, Via Transformer Action: Partnered Output Coils - Why it's Important to have Current Flowing!
I have had to laugh, I read several times the sentence: "its too good to be true" - You will not believe it when you see it! I promise you of this! It is simple, it is cheap and it is fully understood all through standard Scientific means and we are not breaking any of the gospels of Science!!!
It really is so simple!!! Partnered Output Coils are a Solid State Electrical "Generator"!!! Via Faradays Law of Induction!!! Where the Magnetic Fields Change over Time!!!
   Chris Sykes
       hyiq.org
