0 Members and 183 Guests are viewing this topic.
EMJunkie
Many may not realise, not yet connected the dots, but this is a Feed Back/Feed Forward arrangement!!!
When it was said:
Quote from: Walt Rosenthal - URL: http://amasci.com/freenrg/sweetvta.html
The VTA "likes" to always see a minimum load of 25 watts.
The reason for this is the fore mentioned Feed Back/Forwards! Because the Magnetic Field Density (B), is, as was mentioned: B = µNI/L - The Magnetic Field Density (B) is determined by the Current (I) in the Coils and the second Rule of Faradays Law of Induction is the Flux Strength (H) which is: B = µmH, or commonly just: B=μH
So, by Increasing the Current (I) we Increase the Magnetic Field (B), thus we have a higher Separation Rate of Charges in the Partnered Output Coils (AKA: Faradays Law of Induction) and thus Power on the Output can be Increased, simply by Increasing the Current! Is it Kirchhoff's Law that states this?
This is really Important to see and understand this simple fact!
Kirchhoff's Voltage Law
Kirchhoff's Current Law
Please Note: Kirchhoff's Law's doesnt appear to take into account the "Generation" of electrical Energy in a Circuit. This is a separate System and not considered to be Nodal.
   Chris Sykes
       hyiq.org
EMJunkie
I said I would post it when I found it: I found it!
I believe "Zilano" has connected the Dots, thanks to (Zilano == Female ? her : his) work, and the documentation provided, I found the schematic I was looking for.
Ref: Don-Smith-Rep-Zilano-Posts-Updated-Jan-11-2012.pdf
   Chris Sykes
       hyiq.org
EMJunkie
I do stress, there is no need to go to these extremes!!!
Use Low Voltage, Low Frequency, the methods I have shared with you and study them carefully!!!
--->>>   Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation
--->>>   Partnered Output Coils - Why it's Important to have Current Flowing!
   Chris Sykes
       hyiq.org
Magluvin
Quote from: EMJunkie on March 31, 2016, 07:43:44 PM
   Chris Sykes
       hyiq.org
Looks like a simplified Don Smith.  Ive argued in the past that Dons 2 coils may be set up like what you talk about. Were they?
Mags
EMJunkie
Quote from: Magluvin on April 01, 2016, 05:25:57 PM
Mags
Hi Mags,
Your question is difficult to answer correctly and accurately, for the simple reason that, there are many ways to make this work.
The basic ideas are still the same however!
A Coiled Conductor in the presence of a Magnetic Field changing over time is Electromagnetic Induction. This is a limited Energy Exchange because of Lenz's Law. More out than in is "Impossible" because for every Unit of Force we put in there is an equal Unit Force that Opposes us... Dada dada dada you know the storey...
Engineering Lenz's law, so we have the ability to use these Units of Force to work for us, instead of against us is the only logical approach to finding a Solution!
It's funny, I used to use the analogy of two Fire Fighters aiming their Fire Hoses at each other... Now I have a better one and I would like to share, this, as we will mostly, be able to relate better.
Please see the below Image:
Maximum Energy is reached when Forces oppose directly. The analogy here is Our Input, vs Our Output. Each Opposing, Each at maximum Energy for the System.
Let's think about how we can use this Opposing Force to Increase the Energy in the System...  What is moving Forward from each Source can be routed, like Routing a River... An Energy Exchange from one side to the other... Let's say Iron Patriot had a Higher Energy Source, Iron Man could absorb some of the Energy and re-route it back, if you like, to assist in Ironman's action.
So here I have terribly explained the analogy and not answered your question... Yes, the basic Principles are all the same, no matter what arrangement, no matter what the Circuit, two Output Coils, work together, Magnetic Fields Oppose, the Electric Field adds, one from Each Coil, where one would normally have a singular Electric Field from one coil as we normally use a singular Secondary Coil...
Don Smith did use the same techniques to "Generate" an excess of Electrical Energy, as have many others, Paul Raymond Jensen, Earl Koenig, Floyd Sweet, Melvin Cobb, T. H. Moray, Lester Hendershot, Stanley Meyer, Gennady Markov, Alexander Frolov, Andrey Melnichenko, Mishail1971, Vladimir Utkin, Bill Alek, Tom Bearden in the MEG, John Bedini in his myriad of devices, and the list is endless and I could not cover all these people...
EDIT: Of course, Wistiti, Yuri Likhovid, (Юрий Лиховид ), Thaelin and others that do not wish to be mentioned also are in this list!!!
   Chris Sykes
       hyiq.org
P.S: The commonality, an Excess in Electrical Energy = 2 Output Coils working together to Invoke Electromagnetic Induction beyond the Entropic Limitation of Lenz's Law in a Singular Primary Secondary Coil Arrangements...
It really is that simple.
