synchro1
Quote from: MileHigh on January 31, 2015, 06:36:25 PM
The only reportable person will be you.
Go ahead and follow through with your threat and find out where you really stand in the pecking order.
@Conrad: You don't specify that your output current and voltage numbers are RMS, but I hope that they are.
Are these RMS values taken from the scope's computation "numbers in boxes" or are you taking the peak voltage of the sine waveform as displayed on the trace and dividing it by square root of 2?
In any case could you please repeat the output measurement by reading current through a 1ohm or 0.1ohm Current Viewing Resistor in series with the load resistor, using two probes, one for voltage across the entire 101 (or 100.1) ohm load, and one just across the CVR itself for voltage drop=current.
I am always a bit suspicious of using a high-value CVR, and also of using the load itself as the "CVR" in power measurements.
There may be some information in this document that you would find helpful:
http://web.pdx.edu/~bseipel/Alternating%20Current.pdf
synchro1
Quote from: TinselKoala on January 31, 2015, 06:41:47 PM
You are indeed an astounding hypocrite. Conrad is a "bootlicker" when his results don't please your preconceptions, and when they do, he's a candidate for "world records."
Please show how (4/π)2 relates to 2kHz in some "harmonic node" fashion.
4/π =
1.273239545...
1.273239545... x 2 = 2.546479089...
Or is the "2" supposed to be an exponent?
(1.273239545...)2 = 1.621138939...
None of which come anywhere near 2000 Hzor anywhere near an integer divisor or multiple of it. So explain your use of "harmonic node" and how (4/π)2 corresponds to 2kHz in such a manner.
I changed my mind about Conrad! The harmonic has to start at the frequency of first wobbultion!
Quote from: picowatt on January 31, 2015, 06:55:24 PM
Conrad,
For input power calculations, should not "Vr" actually be "Vh", and therefore closer to 7mw in?
PW
This is indeed confusing. The probes are connected so as to provide essentially a "differential" measurement of the voltage across R1. Why would this not be a valid current measurement?
Hmm.... at these frequencies with a nice sinusoidal waveform, an ordinary DMM connected inline will usually provide quite accurate measurements of average current, won't it?
Quote from: synchro1 on January 31, 2015, 07:19:53 PM
And you'll change it back again before this is all over, I'll wager.
Now please address the actual challenge before you:
Quote from: TKPlease show how (4/π)2 relates to 2kHz in some "harmonic node" fashion.
4/π =
1.273239545...
None of which come anywhere near 2000 Hz or anywhere near an integer divisor or multiple of it. So explain your use of "harmonic node" and how (4/π)2 corresponds to 2kHz in such a manner.
