0 Members and 61 Guests are viewing this topic.
Quote from: synchro1 on January 31, 2015, 07:17:31 PM
Go ahead and follow through with your threat and find out where you really stand in the pecking order.
Let's not forget the real issue:  You are abusive towards me and you are harassing me and you have been doing it for more than a year.  Stop it and the problem goes away.  Or you may find yourself like Wilby, kicked off of the forum because you deserve to be kicked off of the forum because of your behaviour.  It's time for you to act like a self-respecting grown man.
ramset
Syncro
People doing over unity experiments here have requested MileHigh's help.
Thanks Grandma
Void
Quote from: TinselKoala on January 31, 2015, 12:47:18 PM
What I'm concerned about is the possibility of a "scaling factor" in the data file that is dumped to the spreadsheet. So if you could actually look at the data files themselves, when the vertical deflection is set to 1v/div and 5v/div on the same waveform, to verify that the voltage values in the data files are the same, and not scaled by the change in vertical deflection display values, that would be very helpful.
Hi TK. No, the data sample voltage values recorded to CSV file reflect the actual voltage values,
regardless of which volts/div setting you have. Of course the voltage values are more accurate if you have
the volts/div setting set such that the waveform fills as much of the screen vertically as possible without
being cut off.
All the best...
Quote from: Void on January 31, 2015, 08:31:56 PM
being cut off.
All the best...
OK, thanks for checking.
