0 Members and 203 Guests are viewing this topic.
EMJunkie
Quote from: seychelles on July 07, 2016, 06:13:22 AM
Chris all due respect ,but where oh where is the PUDDING.. You know
the free energy circuit so that we can replicate it.. Even Tesla, MORRAY, STANLEY MEYER,
AND GANG seem to
have died with their free energy secrets.
it seems that there is one free energy device on the market now
and it is THE FAMOUS SOLAR ELECTRICAL CELLS..and and the ATOMIC POWER SYSTEM...
@Seychells - This I have posted before, a few times: http://vixra.org/pdf/1204.0084v1.pdf
Notice the words: otherwise the transformer will require more input power than the output power
Do you see? See how simple this is?
How important this is?
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: darediamond on July 08, 2016, 04:23:24 AM
Hello Chris.
Thank you for your selflessness.
I please need your guidance as I progress.
Presently I am making with my homebuilt machine lizt wire who h I want use to make the Bucking coil. The lizt wire or multi strands wire is.meant for the individual primary. I choose this as to indivially boost the.magnetic power of the primaries before ever driving them and whatever frquency . But what I am deeply confuse about is how the bucking coils should be connected. Should it be in Series or Parallel?  What is the correct Pole to Pole? Should  North to North of the Primaries face each other or is the South to North?
Please clarify.
I do not know electronics so I plan to use car spark plug. Will that be okay?
Also can I use Both AC and DC(pulsed) to Power the Primaries?
Please help me out on each of the questions I raised one after the other.
Thank you.
Your device has nothing to do with what I have shown. Please take this to abother thread.
If you want to Build Partnered Output Coils then I can help. Please see your Personal Messages.
   Chris Sykes
       hyiq.org
darediamond
I have just finished  downloading and watching the videos but my simple questions are not answered by you there.
My proposed configuration will emulate straight core not square core like the one you use in on of your earlier model.
In your set-up, you wound your primaries and secondaries  without separating each layer of Primaries with an insulator to increase the capacitance of the Primaries and plan to modify that using spiral winding as oppose to helical winding.
The multifillar wire is meant to increase the magnetic power of the primaries before connecting them together in correct order which I asked you but failed to give a simple reply to.
You do not have to give me fish Mr.Chris all I needed from you is Fishing tool. But I was surprised by the way you kicked me without redering the needed help by answering my simple questions.
****What you called a Device is not a device but rather a.machine for.making Powerful Coil Wire.
My propose design is only a sligth step-up of yours as I have decide to subtract and add certain things to make it simpler to replicate. But you did not see that.
I only need simple direct answers to my raised questions. Leave the rest to me as I bent on making further modifications where necessary.
After replicating yours, I still gonna pull everything apart again and try to replicate Richard Wills Back EMF enhancer MoGen Device as well as Silverhealtheu's straight core 1 Primary  Generator too before I finally build the  Rotary MOGEN of David Waggoner Of Creative Science and Research in USA. For all this, I am gonna use the same powered wire which you saw it making machine ealier.
wistiti
Hi darediamond.
I think using a litz coil for the primary is a good idea. It may give a much stronger magnetic field and it is exactelly what we looking for :)
Just start to use one of them on a magnetic core and 2 bucking coil (POC) with at least twice the turn of the primary. You can pulse or sine the primary and look of what you got on the POC output...
You can play with frequency, resonnance, load, number of turn,etc.... But the only important thing here is to PLAY with it. Only experience will talk for itself.
I think you are a builder so you may see some result...
Good luck! :)
EMJunkie
Quote from: darediamond on July 08, 2016, 05:41:25 AM
Using a Device to wind Litz Wire, and showing the device here, when I have never used or shown Litz Wire is off topic. Nothing to do with what I have shown.
If you want to learn what I have shown, then you need to follow what I have shared, or you are not learning what I have shared!
Which is off topic and needs to go in another thread.
1: Magnetic Fields are Symmetrical Structure, they need a Closed Core. Rectangular, Toriodal or the like, unless an air Core is used.
2: I have always shown single filament Coils, but Dual, Partnered Output Coils.
3: Keep your Device small and cheap, learn as much as you can from a single device then make improvements LATER ON!!!
Most Important: Look for the effects I have shown...
I have repeated myself perhaps some 2000 times in this thread. None listen, all know better...
We all have our own path, but if one is after something in particular, then one must focus and direct ones concentration for a single goal. Not spread the load in other places where Focus and Attention is drawn away.
You decide.
P.S: All your questions have been answered in this thread and in my videos, directly or indirectly, if you pay attention.
   Chris Sykes
       hyiq.org
