0 Members and 156 Guests are viewing this topic.
EMJunkie
I just cant help myself: http://overunity.com/16724/graham-gundersons-energy-conference-presentation-most-impressive-and-mysterious/msg488649/#msg488649
Quote from: MileHigh on July 19, 2016, 08:34:44 PM
The moment you see actual permanent magnets incorporated into some kind of magnetic circuit that is effectively functioning as a transformer then warning bells should be sounding.  Except for a very few specialized applications, adding permanent bar magnets to magnetic circuits to "bias" them is usually nothing more than electronics quackery.  The simple test is to run the setup with the permanent magnets in place, and then run the setup without the permanent magnets in place.  The reasonable expectation is that the circuit will perform better and have more power headroom without the permanent magnets.
I anybody builds this (Do we know what the configuration actually is?) then I strongly recommend testing it with and without the permanent magnets.
Also note that depending on the magnet, you may be demagnetizing your permanent magnet when you place it in some sort of AC transformer setup.
Typical, no idea on how an Electromagnetic "Generator" Works, or Electromagnetic Induction works at all!!!
Proof youre wrong: Flux Gate Magnetometer or Solid state Generator?
Hahahaha MileHigh. Soon you'll be the only kid on the Block that does not have a BMX!!!
   Chris Sykes
       hyiq.org
EMJunkie
I really must say, I believe the absolute most important Piece of the Puzzle is the Starting Line...
You can not start a Race at the Finish Line!!!
Research into the Field of Energy surely the first most important basic step is to know how Energy is "Generated"!!!
Again, for those reading that have not already: Start at the Start
Quote from: EMJunkie on December 20, 2015, 01:55:01 AM
After some 439 Pages, I hope we have now got a message of hope through to people running blindly down dark alley ways!
Induction is Induction, Electrical Energy comes directly from Matter/Mass - This is known as Mass/Energy Equivalence! It is Einstein's E = MC2
Surely the supporting evidence I have provided give's at least some people a step in the right direction:
Electrical Energy 101 - Faradays Law of Induction - Part 1
Electrical Energy 101 - Faradays Law of Induction - Part 2
Electrical Energy 101 - Faradays Law of Induction - Part 3
Electric Motors DC Motors and Generators - Part 1 - 1961 US Army Training Film
Electric Motors AC Motors and Generators - Part 2 - 1961 US Army Training Film
Electricity & Electronics - Current - 1974 US Air Force Training Film
Electricity & Electronics - Voltage - 1974 US Air Force Training Film
How Magnets Produce Electricity - 1954 US Navy Training Film
So, two equations, two ways of Inducing an EMF in a Conductor: EMF = Bvl and EMF = dPhi/dt
Here I show you some basic first principals: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation
and, some more Principles: Opposing Magnetic Field Interactions - Partnered Output Coil
Three Coils:
   1: Input Coil
   2: Partnered Output Coils - Two Coils working together to Self Assist in the Frequency of Operation!
A good example of this is given here: Partnered Output Coils: Anti-Lenz effect - from: Юрий Лиховид (Yuri Likhovid) - Orriginally invented by Wistiti - Partnered Output Coil Toroid Feb 25, 2015
Note: There must be Current flowing in the Partnered Output Coils for this to work!
Please, always remember, Lenz's Law is a Magnetic Drag, fix the Magnetic Drag and you have got Free Energy!!! Magnetic Field is Current Flowing in the Coil Conductor.
   Chris Sykes
       hyiq.org
P.S: When others are set in their ways, its not just their Potential that they limit, its others that listen to their advise. See with Logic and open Eyes, not through others.
   Chris Sykes
       hyiq.org
EMJunkie
I had a question the other day; It gave me a perspective from a point of view I did not expect. It is so hard to verbalise something, especially when one is still learning in a very broad and complex field, and get across valid important points.
This may be a long post, I will try to keep it all relevant and to the point.
Floyd Sweet said in his Lab Notes; Flux has to be moving - this can be found on Page 4: Floyd Sweet's Space Quanta Modulator - Lab Notes by Darrell Roberts. Signed and added to by Floyd Sweet. Transcribed by hyiq.org
This is true for all devices, The MEG, Flynn Parallel Path, Flux Gate Magnetometer and so much more...
Normally a large current is associated with shifting a Magnetic Flux.
Normally the Current x is going to exceed slightly the Flux of the Permanent Magnet. That is if we take this on a one to one ratio, where 1 Gauss is equal to 3.335641e-10 ampere, which is arbitrary because the Turns of a Coil, or the Inductance is deterministic of the Magnetic Field in Gauss (B not Φ ). It is odd, because this is one of the problems I have faced and is a little bit of guess work for me even today after many years of experiment.
To put some perspective on this, I had made many experiments with the Flux Gate Magnetometer, one experiment I show here: Flux Gate Magnetometer or Solid state Generator?
You could ask the question, why did I add the term "or Solid state Generator?"...
That is, because this is exactly doing just that! The Movement of the Magnetic A Vector Potential produces an EMF in the Output Coils.
The Output Coils are NOT Inductively Coupled to the Input. Draw as much Current as you can on the output and it does not affect the Input at all!!! However, it does take a large current on the Input to get the Magnetic Flux Moving. I was using 9+ Amps into the Amplifier, which was not very efficient. I think it's important to see the Concepts here for what they are, and possibly, this is best to actually do a few simple experiments to prove the concepts and see for yourselves... All in all a very interesting and informative device!!!
So, the Magnetic Flux Has to be moving, or one could say that the Magnetic A Vector Potential must be moving. I show this here: Faradays Law of Induction where the Core is Magnetised, the so called Magnetic A Vector Potential is apparently on the Core, but a movement of the Coil on the said core shows no EMF "Generated"!!!
So, its not enough to just have the Magnetic A Vector Potential present, it must be moving.
What if, the very movement of the Magnetic A Vector Potential itself, can be invoked into a Self Assisted Oscillation?
I show this here: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation where the very motion of the Magnetic A Vector Potential itself can Assist in the Oscillation, or the Operational Operation!!!
Floyd Sweet was quoted twice saying the samething:
Quote from:  Jeane Manning - A New Physics for a New Energy Source - Free Energy - Making the Impossible Possible
On rare occasions, Sweet saw this effect, called self-oscillation, occur in electric transformers
Quote from:  Tom Bearden - Energy From The Vacuum
Sweet was also a transformer designer and expert, and he remarked that he had also observed specialized self-oscillation in certain transformers.
Why is this important?
Well, if we have to use 10% less Input, because of the Self "Generated" Electrical Energy, to a System that is 90% Efficient, then we reach Unity Performance! If our Input goes to 50% on  the same System, then we have OU by 40%... You get the Idea.
But, it is very important that the Flux, or the Magnetic A Vector Potential is moving, thus my video: Partnered Output Coils - Why it's Important to have Current Flowing!
This video, should also, very clearly explain the easiest way to get the Current Flowing...
It just so happens that Other Effects follow in this type of System!!! Lenz's Law is Negated!!! Yes Lenz's Law is no longer valid!!! because of the Magnetic Field Interactions in the core. This I have already been through in many posts also. I have very clearly shown in Video form, the same things here: Opposing Magnetic Field Interactions - Partnered Output Coils
What I have shown and explained for many years is not the only way. This is one way, perhaps one way of many, to achieve an end result!!! What is sure, that the easiest way to achieve a result is: Partnered Output Coils bought into an Oscillatory Opperation, with a Resonant Input where all your Input Power, you get back again! Reactive Power!!!
   Chris Sykes
       hyiq.org
EMJunkie
It is well known that Rats can Swim, however it is also well known, and, as the saying goes: Like Watching a bunch of Drowning Rats
Don't drown in the myriad of un-knowns, but use Diakoptics to break down every single piece of the puzzle...
As I have said, Start at the Start:
   1: Learn how Electromagnetic Induction works!
   2: Do small simple experiments to prove/disprove simple concepts. Know WHY something does, or does not work!!
   3: Think outside the Box!!! Never ever let anyone or anything limit you, for all boundaries are imaginary!!!
It is NOT True that you can only get to work in a HumVee, you could get to work in a VW also! One may have a preference for one or the other, this is not a limiting factor, however...
The truth here, is that the key principle is, a Vehicle is Transport to and from work, not anything else but that. To Ass-U-Me anything else just makes an Ass out of U and Me. Assume Nothing, ever!!!
   Chris Sykes
       hyiq.org
EMJunkie
Too much GREED, too much Selfish incentives, too much thought about the NOW, and none for tomorrow...
We Humans are Doomed for Failure, in pity, in self-delusion, in self-destruction, in pain, torn between Animal Instinct and Spiritual Evolution, the torture does not bring change...
In luxury live today, in Rust live tomorrow...
I thought we were better than that! There is no, I, in Us, one species...
And some wonder why I keep something's close to my chest, maybe this might be clear now...
   Chris Sykes
       hyiq.org
