0 Members and 45 Guests are viewing this topic.
forest
All I can say is if I could have a very long ferrite rod I would propose experiment with primary on one end and secondary on other. Do you agree there is no flux cutting here ?
We are using almost everywhere flux linking (transformer) action, except some small flux cutting when primary and secondary occupy the same space but it is always due to collapsing /expanding field. Having flux cutting in generators only we have  almost no ou devices around.
EMJunkie
Quote from: forest on July 30, 2016, 04:06:57 AM
Hi Forest,
Yes, this could be an example of both, Flux Linking and also Flux Cutting. Because there is no Closed Magnetic Path, the Magnetic Flux will be forced to traverse the Air. Funnily enough, this is also another good experiment to try!
Make your coils sliding on the core, take eff measurements at specified distances (1cm progressively) appart from each other. Post your results!
This will show the same thing above, at a greater distance appart the efficency will drop off. More Flux Leakage will occur between the coils, so the further you move them appart, the less efficent the induction becomes.
Also on another note: I wish he was still posting videos: Large secondary loop transformer - excellent experiments from Raselli1.
   Chris Sykes
       hyiq.org
EMJunkie
Webby1, you got a fair bit of the sour grapes happening old mate?
Quote from: webby1 on July 30, 2016, 08:11:53 AM
O.H. was a genius for being able to reconcile the two different views and provide us with something we could use to use some part of this interaction.
I am used to it now, some 470 pages later I been dealing with this for a long time now. Lets not forget, I did provide the reference/study material several posts back.
Quote from: EMJunkie on July 29, 2016, 05:38:52 PM
You should study Feynmann and Cohn - These guys show experiments with results.
V2 Ch15 Vector Potential.mp3
V2 Ch16 Induced Currents.mp3
V2 Ch17 Laws of Induction.mp3
V2 Ch34 The Magnetism Of Matter.mp3
V2 Ch36 Ferromagnetism.mp3
Vol2_Ch_15_Vector_Potential.pdf
Vol2_Ch_16_Induced_Currents.pdf
Vol2_Ch_17_Laws_of_Induction.pdf
George I. Cohn - Electromagnetic Induction
All of which said exactly as I have re-explained for about the 1000th time now.
This just makes no sense:
When will the flux fall into the permeable core for the return path??  since it finds it easier to fight against itself within the core than through the air.
Is it even supposed to be a question? Umm, as long as it is not Saturated it will allow Flux.... Is that what youre after?
It is not good to try and take the "how we can use things" to explain the "what they are things"
Your:
   what they are things - Magnetic A Vector Potential (sometimes referred to as the Motional Electric Field)
   how we can use things - Same way we always have done??
I certianly did not give any other response than was any different from what Cohn and Feynmann have given me, Criticising my posts is a low and dirty thing to do when you have nothing to offer at all!!!
What is a charge carrier??? that one is still being debated, and yet it creates these other things???  and then from there someone is going to make a statement of the absolute nature of something??
A little Man that Sells Batterys for a living? Dude, youre trying to out do yourself with with some strange confusion tactic?
Any particle that has Charge and moves. Simple, not hard. Ion is one example, Electron another.
Dont come to this thread and disturb it with your BS and Bad Attitude.
For others: I dont have all the answers, I am still learning too! I only share what I can, from the experience I have gained. I always try to provide reference material and data to back up what I share.
It is up to you to make your own minds up!!!
   Chris Sykes
       hyiq.org
Magluvin
Here is something the pdf says, but in my own words...
If all the field of the primary on a closed core is contained in the core, then when current is applied, how does the field know where to be when it comes into existence? How does it determine where to appear before it is created??? How does it determine that the core is there at all in order for the mag seed to be planted? lol
Mags
forest
If we place primary on one end of long long ferrite rod and secondary one second end I don't see how the flux from primary can cut secondary. There should be NO current generated in secondary, nada, zero, no microamp even.
What if the actual experiment show there is induced current ? Is that due to electric field generated when ferrite magnetization changes ? I don't know. Definitely it's not flux cutting for me
