darediamond
Quote from: EMJunkie on July 21, 2016, 06:11:40 PM
Oh, to help a bunch of drowning Rats, because I am no sadist and have a heart that works, I am not limited to posting here...
First, I have seen this before, I cant stress this enough, it is so very important in this field!!!
NEVER CHANGE THE ORIGINAL STOREY!!! EVER!!! NEVER CHANGE THE ORIGINAL DATA, EVER!!!
First Basic Truth: In one AC Cycle, there is 2 Magnetisation Cycles in any Coil. See Below Image: Meaning the Coil flips from North South (Positive Current), to South North (Negative Current) during this Cycle.
Second Truth: The polarity of the Dots on the PM's do match EXACTLY with the original Storey!!! See below image: 2 sets, that's Two Sets of Fields are Present here from the Permanent Magnets, there has to be for this to work in this configuration!!! Why would the dots be aligned this way and the original storey match, EXACTLY, the dots, showing clearly, very clearly, that there is a specific configuration that is being aimed for... Graham told Reiyuki  how the Magnets were setup, the dots verify this, and now the storey has been changed...
Third Truth: The Lower C Core is Higher Permeability so as to make an easy path to travel for One of the PM Fields at any one time.
The Very Heavy Duty of the Acrylic and Nylon Threaded Rods indicate a lot of pressure in the Magnetic Fields in this configuration...
Again, the Key concept here is Moving Magnetic Fields!!!
Carefully study this, dont take anything for granted!!!
   Chris Sykes
       hyiq.org
P.S: Sorry, I posted the wrong Poarity, I have correced it now.
Chris, you have just revealed a killer info!!!!!!
But then, how can this be applied alternatively in Figuera Genertor which is the opposite of Partner Output Coils (2 input coils and One outputncoils at the center)??
EMJunkie
Quote from: darediamond on August 03, 2016, 02:04:48 AM
Figurea himself said that he sold the Patents to the Bankers.
My first thought is the existing Patents or what has been given as a patent may not be trustworthy! What Banker do you know that is trustworthy? Yep, none, me too!!
The guys are making excellent progress here on ou.com, but seems there is still a big nut to crack there. News paper Articles are about the only source I would trust.
   Chris Sykes
       hyiq.org
EMJunkie
If there is one important thing that has value, is when Figurea said that his device was based "How and electrical Generator worked"
   Chris Sykes
       hyiq.org
darediamond
Quote from: EMJunkie on August 03, 2016, 03:33:24 AM
   Chris Sykes
       hyiq.org
Chris, are you a Banker? ;D ;D
darediamond
Quote from: EMJunkie on August 03, 2016, 05:14:41 PM
   Chris Sykes
       hyiq.org
Chris, what do you think will happen if 2 Primary Windings with one secondary bat the center sharing the same core are connected in such ba way that when the primaries are powered, there Polarity Collide at the center instead of ATTRACT I.e instead of there polarity to be N<+>S or S<+>N it becomes N>-<N or S>-<S  ???
Will the centered Primary generate any output in each of the configuration? If Yes, how intense will it be?
