0 Members and 67 Guests are viewing this topic.
darediamond
Quote from: EMJunkie on January 18, 2015, 03:34:48 PM
@ALL
Reading the prior posts to this thread, we now know How Charge is Separated, Where we have Magnetic Fields; E.G; Primary, Secondary, and that the Secondary is in the opposing direction to the Primary!
We know that the Secondary Magnetic Field is only a Result of Drawing Current from the Charge Separation that we have already bought about from the Primary Magnetic Field Changing in Time!
So, its now fair to say that:
Any Magnetic Field Changing in Time Can Separate Charge
So a Secondary Magnetic Field (Lenz's Law) can be used to actually Separate More Charge Carriers!!!
Green Coil: Input Coil
Gold Coils: Partnered Output Coils - Each Coil Increases Charge Separation
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
May your days be long Chris.
Please.come over to Figuera Thread to enlighten people and help them out of darkness one Marathonman is trying to put them into.
I beg you please come over.
EMJunkie
Today I watched a copy of the Graham Gunderson Video - MIT
Graham is very humble, he deserves full credit for his work and excellent efforts presenting it.
We are very lucky, there is no way I could demonstrate my work with such quality, and accuracy that Graham has.
   Chris Sykes
       hyiq.org
EMJunkie
Graham, in this video, has told you nearly exactly what I have told you, except for the fact that Graham totally side tracked the entire topic of Output Coils!
There was not even a mention that there was two Output Coils, at all!!! <<<--- A total side track!!! Infact a deliberate lack of Pluralisation, "Output Coil"... and NOT "Output Coil's"...
Graham said instead: "I have no idea how it works"
But also admitted that the Synchronous Rectification was one of his secrets. Graham did not talk much on that, and no diagrams were shared. A start to how Sync Rect works was started. See bottom Image. What I can say, is, I think it is very similar to Tinman's RT Output Diode/Fet configuration! Tinman will know exactly what Graham is doing. If you've been following, so should you.
Let's face it, the majority of the entire thing is Input!!! A Resonant Circuit, controlled by an H-Bridge, is the Prime Mover, this is attempting to add the Magnetic Flux from the Permanent Magnets to the System... See the second Image at the bottom corner...
Talk of Saturation was mentioned, or at least operating at the Knee of the ferrite Core Material, but Grahams Current Wave forms show he was nowhere near saturated, this I find very odd!!! A Coil of Wire on a Saturated Core, is simply seen as a Resistance, next to no Inductance is present, any Phase Angle between the Current and Voltage will be lost, as the Core Saturates. Phase Angle will move to Zero as the Core Saturates and the Coil of Wire is just a Resistive Element, then total Burn Out of the Transformer can occur.
This is the Reason we do the best we can to avoid Saturating Transformers!!!
No sign of any of this at all is present!!! Phase angle is not changed through the entirety of the Cycle, no indication of Current Peaking on the wave form, there is nothing to indicate at all that Saturation is reached from my bitsy little knowledge in Electronics... I really find this odd...
The majority of the entire System is Input, like I said. There is nothing new to any of this. Graham does have a Stop Time on the end of his Cycle of approximately ½ of the Wave Cycle.
We have been through this before, Reactive Power can do work, its ping pong Power.
Graham uses Ping Pong Power to get the Permanent Magnets Flux Moving in the Core Material, once moving, all, nearly all the Power returns to the Source, this is Reactive Power. VAR, or Volt Ampere Reactive Power.
So, work has been done, for next to no expenditure on the Input.
The Input side is nothing special, nothing fancy, but a lot of Circuitry and Coils/Capacitors.
The Secret lays on the small, completely side tracked in the video, Output side of the device. Again, I have said it before, Two Output Coils is critical.
Once we have a Magnetic Flux Moving, Electromagnetic Induction can be invoked as many times as we can place Coils in the proximity of the said moving Flux. But as I have told you, Graham also, it's the Magnetic A Vector Potential that is doing this Induction, this is an Electric Field.
Remember, One AC Cycle has two Magnetisation Cycles, from North – South, to South – North. One is above the Zero Graticule Line, and one Below the Zero Graticule Line. You can say that the Current Wave Form is the Magnetisation being applied to the Core Material, this being Hysteresis, the BH Curve showing the Curve that has Sign and Magnitude of the Magnetisation.
In the below Image, we see the Input Current on the Input Coil applying a Magnetisation to the Core, marked in Red. Marked in Blue is the Opposite Current (±180 Degrees Out of Phase) on the Output Coil for this part of the Cycle. This wave form was inverted by Graham. He says in the Video. So, this is standard normal Electromagnetic Induction occurring right here. EMF = -N dPhi/dt Transformer Induction.
You can see the Wave forms carry on, there is yet more Induction occurring on the other half of the Magnetisation Cycle, and then it is Chopped via a Switch off of the Synchronous Rectification for 500-1000 Nano Seconds or 1 – 2 MHz. This from Graham.
Graham Gunderson has taken a lot of time to show you the absolute most important things that you may ever see in your life. I can 100% agree with what Graham said and has shown you. I ask you please, please pay attention, learn this stuff, there is many hundreds of hours of information to learn in Grahams Video alone.
This may be the last chance you get to learn the most important thing you ever can!!!
   Chris Sykes
       hyiq.org
EMJunkie
Lenz's Law:
   Input Coil is 50Hz 240V, Secondary 12V, as soon as a Current is drawn from the Secondary, the Secondary Magnetic Field is Reflected back on the Primary Magnetic Field,  Phase Angle will reduce from Current to Voltage and more Current has to flow in the primary as a result of the said Reflection.
Negating Lenz's Law:
   Input and Secondary Invoke Induction, a Tertiary Coil is bought in, Invoking Induction again, but from the Secondary, not the Primary, Secondary and Tertiary Fields Oppose, Primary is left to excite the Device.
Thats why the Primary can stay Reactive and not be affected by the Output Power. The Energy is mostly Confined to the Immediate area of the Secondary and Tertiary Coils. These Coils Invoke Induction between themselves. All you have to do is get the Phasing and Fields correct with enough room from the Primary.
   Chris Sykes
       hyiq.org
P.S: USE THE RIGHT HAND RULE TO SEE WHAT DON IS TLLING YOU:
EMJunkie
It is frightening how much is over looked when there are so many Geniuses in the room!!!
Diakoptics: You need to start asking the right questions, ruling out the basics!
   1.   Is the retarded, or lack of, Lenz's Law response a function of Frequency?
   2.   Can the same device operate at 5KHz?
   3.   How could the Output Power be Real and in Phase, when the Input Power is Reactive?
   4.   What changes the Phase Angle of Voltage to Current?
   5.   ...
To get answers, you need to ask the right questions; rule out the basics, what is left can be the only answer.
Simplicity is always going to be the answer to the most complex questions! An Alternator can be made to run itself with no Electrical Input at all, only mechanical, this means that the Magnetic Field can Support itself!!!
What does this mean?
The Magnetic Interactions are equal and Opposite, the Electrical Output from a System is not determined by the Electrical Input, but the Excitation Frequency and the Magnetic Flux Carrying Capability's. Magnetic Flux Supports itself, and is not a function of any input parameter.
Experiment:
Take a small Electric Motor. An Alternator works real nice!!!
Short the Rotor Coil.
Spin up the Shaft.
Put a load on the Stator Coil...
Result:
With no Magnetic/Electric Energy added to the system, the Magnetic Fields will build and power a load. The Magnetic Fields can Support themselves!!!
Why are the Big "Generators" more than 99% efficient? Less than 1% Losses are Frictional and Windage! Nearly all the Transformation of Energy is from Mechanical to Electrical, this is Lenz's Law!!! The
Magnetic Field Reflected is Equal and Opposite!
   Chris Sykes
       hyiq.org
