0 Members and 105 Guests are viewing this topic.
EMJunkie
Have double checked, but if you see errors please point them out:
mv = ma, scope adjusted for the math.
No channels on the scope have been inverted.
   Chris Sykes
       hyiq.org
John.K1
Hi Chris.
Great work!  Thank you for sharing. I believe, there is more to come. We need just to go to our desks and to experiment. Put in order what we learn and share the results in our community.
I also didn't follow the PRevas setup, I have used the same number of turns L1, L2. The reason is simple finding of resonance point (in my case 900KHz due to small number of turns).   I used CW & CCW coil on small toroid, and I have got output waves completely synchronized (+/- 1 deg) - on my picture it appears as one wave.
I do no want to make any conclusions or final results yet as there can be something overlooked. This is why I ask you guys to scream if you see any error or wrong conclusion ;)
regards,
Jan
wistiti
Great work guys!
It is nice to see some constructive post!
EMJunkie
Thanks Jan/Wistiti,
An early analysis shows we have two branches to deal with here, each having very different, and interesting results:
Input:
Period: 3.320
Offset: 0.160
Degrees: 17.3
Active: 2.203788426168
Apparent: 2.30821
Reactive: 0.686403717929
Power Factor: 0.9547608
L1 Branch:
Period: 3.320
Offset: 0.28
Degrees: 30.4
Active: 8.0004243646859
Apparent: 9.275707
Reactive: 4.6938212608966
Power Factor: 0.8625137
L2 Branch:
Period: 3.320
Offset: 1.72
Degrees: 186.5
Active: -6.1948770793364
Apparent: 6.234956
Reactive: -0.7058169710592
Power Factor: -0.9935719
The circuit needs some work, I need to put the Current Sensing Resistors (CSR's) on the Load side of the Coils to verify the phase angle's seen. As through any Resistive Load, there should always be Zero Phase Angle!!!
Please correct me if you see any errors.
The resonance Frequency is calculated as:
   Frequency F = 1/ (2 * Pi * Sqrt( Inductance L * Capacitance C )) = 1 / 6.28318530717959 * 0.00069065186599328 = 230.44 Hertz, So our result is not far away, including the Damping Factor ζ (zeta) 297 Hertz
Coil L1 is the Resonant Coil, L2 is would be seen as our Tertiary Coil from discussions, but is our Secondary, from Secondary Induction.
Once understood, Partnered Output Coils work exactly as I have said. To understand them makes for simplicity, to not understand makes for failure or a lucky mistake!!!
Jan obviously knew when showing this circuit, what it was!
   Chris Sykes
       hyiq.org
Polarisz
GREAT JOB!! CHRIS and JOHN!!
I have reviewed yours and Chris's replications, and would like to do a replication my self and post results. I'm not sure If it matters for my replication. (probably doesn't) But would you please share Your cap size, length of wire of l1 and number of turns for l2 and l3?
