0 Members and 181 Guests are viewing this topic.
EMJunkie
But:
Quote from: EMJunkie on July 13, 2016, 03:28:49 AM
I can hear everyone asking: WHY?
Well, in every Electrical "Generator", Ohms Law applies, in combination with Faradays Law of Electromagnetic Induction. What does this mean?
Voltage is directly a result of the Time Rate of Change of the Electromagnetic Flux, the Faster the Rotor Spins, the Higher the Voltage!!!   <<<--- This is a KEY Sentance!!!
The Higher the Voltage, the Higher the Current goes, for a given Resistance, this is simply V/R = I!!!   <<<--- This is a KEY Sentance!!!
So, simply, if there is NO Voltage (V), there can be no Current (I) (In an Electrical Generator) through a Resistance (R)!!!   <<<--- This is a KEY Sentance!!!
And so, the wheel work of Nature, depends on, the Time Rate of Change of the Magnetic Flux, The Resistance, The Voltage "Generated" and the Current will follow, only in these configurations.
   Chris Sykes
       hyiq.org
barbosi
Quote from: EMJunkie on October 02, 2016, 04:08:27 PM
Electrical Energy is right there, ready for you to Invoke it, the Magnetic Field is engineerable!
For the first time I agree with you.
While breathing normally, I'm looking forward to hearing about your success.
Wink!
When the Power of Love overcomes the Love of Power, there will be peace.
Utopia Now
Hallo Chris and others,        Grenade Coil Pulsing, Variable Cap
I want to understand how it Works
Is it this Ringing effect  what is needed for a good working device ...
Video :  Grenade Coil Pulsing, Variable Cap   https://www.youtube.com/watch?v=_uDusLU5IPQ
In the video there is only a square wave from the function generator but when we have a stronger inductive kick  is that  what  makes the amplification possible ?
SR193 (just) had a small spark  https://www.youtube.com/watch?v=rbkvXoDfk7g
Kapanadze   maybe  bigger spark   https://www.youtube.com/watch?v=ADr1lT9MeIE
And Dally  Nanopulser
https://www.google.nl/search?q=dally+2012+nanopulser&espv=2&biw=1680&bih=965&source=lnms&tbm=isch&sa=X&ved=0ahUKEwic3MPe5LvPAhUGVRoKHX5mD5oQ_AUIBigB#imgrc=_
I just want to understand how it works : is the blue signal on the scope  the  signal  we are looking for.  I know  on the video (Grenade Coil Pulsing, Variable Cap)
it is just mili Volts  but if instead of function Generator , if we use powerful inductive kick .. are we on the right track than ?
Here an other video with the specific signal  : Ringing Whale wave 002    https://www.youtube.com/watch?v=itl-nFy_AT4
If I understand it better  I will be able to  maybe replicate a working device
Thank you for your very helpful  posts
I am Happy
Utopia Now
                   ...... the Magnetic field(th) is engineerable !...
                   the soft or hard metal(l,metal means translated?) magnetic field(th) here meant ?
                   a. magnetic tape,magnetic cassette,floppy disc,......,  CD/DVD/MP3/MP4/stick,"tesa film"
                    b. engineerable : recorder /writer
                       R.O.M. and R.A.M. memory
                       L.A.S.E.R. as reader and writer
                       M.A.S.E.R. as reader and writer
                       http://www.energynews.gr/electric.htm  electro-magnetic generator solution
                                   electro-magnetic human conscious space "instrument/tool"
with chances and danger between AMOK( read left to right and right to left) and KOMA(read left to right and right to left)
                                            FRAKTALE
                                            LUESCHER
http://www.luscher-color.ch/base.asp?p=InfoPeriodischesSystem.html&s=d&m=m_theorie.asp
http://www.colorquiz.com
                  "3.eye" as Gart(-organ)/Wart(-organ)  :
                   https://www.youtube.com/watch?v=ZtLkzg8bFgA
                                               TELESPACE :Gottesreich
                                        https://www.youtube.com/watch?v=yl4bxfzKM3w
                                        https://www.youtube.com/watch?v=c1RUUVNKDuk
                                            PSI                PSALTER
EMJunkie
Quote from: Utopia Now on October 02, 2016, 05:31:00 PM
I am Happy
Utopia Now
Hey Utopia Now - Electromagnetic Induction only requires a Change of Flux over time.
But, I have found a Sinusoidal Wave is best - This is a gradual change over time. Easy to control and easy to use.
DC Pulsing I do not prefer, sharp peaks, which can be nasty on your equipment. This is unless a Resonance can be established.
I have shown many times the basic steps that are required, we even saw some experiments. Don Smith also tells us as do many other famous experimenters.
Quote from: Floyd Sweet - The Space-Flux Coupled Alternator
Current is deemed as a quantity or number of charged particles moving from P1 to P2 in time t, or as the charge transferred in one second by a current of one ampere. The coulomb is the charge on 6.24 x 1018 electrons. Electric fields are due to the presence of charges. Magnetic field effects are due to the motion of charges. Current is the net rate of flow of positive charges. This is a scalar quantity.
In the specific case of positive charges moving to the right and negative charges to the left, the effect of both actions is positive charge moving to the right. Current to the right is: I = + da+/dt + da-/dt. Negative electrons flowing to the left contribute to the current flowing to the right.
Superposition is Key:
   See: My MRPreva Experiment - Image below
   See: Don Smith - How to Generate Energy - Use the Right Hand Rule to see what Don is Saying!!!
As I have pointed out, these concepts are the start, there is a little work and a lot of understanding to this. But if you want it, then you will be more than happy to work for it.
The current and potential windings require relatively little power, and are applied in such a manner that rate of flow of moving charges may be accelerated beyond 1 ampere = 6.24 x 1018 electrons⁄second. Thus the duty factor of the copper changes.
I2 Losses diminish and more charges drawn from the now coherent space field flow at a faster rate as current to the load.
This means as more current is required by varying loads more feedback magnetomotive forces free more electrons from binding forces complimented by potential magnetic forces of the orientated, coherent space field.
Thus a conductor that formerly had a temperature rise above ambient labelled as a factor of 10 would now operate at a temperature of 1.0. Thus the same gauge wire would carry 10 times more current at the same temperature.
An example: Tariel Kapanadze, the Grenade Coil as you pointed out, this Coil is inherently non inductive as we would call it. Having little to no effect on the surrounding resonant circuitry in the form of Lenz's Law, Magnetic Reflection.
But a sharp spike does what? Injects a very fast, Magnetic Field, Time Rate of Change, inducing an EMF in the Grenade Coil, but this is too fast for any negative action. So the Coil has no choice to Engineer Current, because the Current is dependent on the Voltage. No Voltage (EMF) no Current
Of course there is more to it than this, Earthing and so on...
   Chris Sykes
       hyiq.org
P.S: Voltage Transformation is Free, Step Up, Current Transformation is not, we must Engineer the Magnetic Field for Current. MrPreva Circuit, aka Partnered Output Coils do exactly this!
