EMJunkie
Again, I point out: Anti Lenz Effect - Yuri Likhovid (Юрий Лиховид) - Original Inventor: Wistiti (Published on Feb 25, 2015)
Quote from: Yuri Likhovid (Юрий Лиховид)
My dear friends abroad,
This is my first experiment with a Toroidal Transformer for a power of 1.6 Kilo Watt. My Transformer has one Primary Winding and two secondary windings. Each Winding is wound separately, this means that the end of the first winding is end, and the begin of the of the second winding, is separated by a Gap!
So we have two Gaps!
Here and Here.
According to my telly, one of the secondary winding is connected oppositely with respect to the primary winding, so that the Magnetic Fluxes of the Coils, are facing each other.
   Chris Sykes
       hyiq.org
P.S: @Utopia Now - Good Work! Sorry I should have said that first! My reply was a general one and meant for all.
         Minkowski (Teacher from the later Dr. Albert Einstein) Space(RAUM)Time(ZEIT)
                                             the continuum line
               phase shift (~change) 3/4 Dimension XYZ-Coordination-system
                             3-freedom degrees rotatory,translatory,linear
Time : chronos      a-/synchron   Synchronicity/Realtime(ECHTZEIT) Resonanz/Harmony(Pitagoras)
Utopia Now
Thank you Chris for your explanation.
I have an other question    there is this patent  that you probably mentioned some time or it is somewhere on your website or pdf`s
But I  like to read, see it again ..
It is about CW CCW  configuration    and in the   end of the patent  they  say  it is also specialy  good  to  produce stronger magnets  with it.  (  because  with their configuration  they can produce more Amps and Tesla`s )
Do you recall  that  patent  Chris.    Can you tell me  what patent that  was.
Thank you
Utopia Now
EMJunkie
Quote from: Utopia Now on October 05, 2016, 07:12:43 PM
Thank you
Utopia Now
Hi Utopia Now - Most likely Earl Koenig, Patent: US 4806834
This is the best evidence of working Patent Protected use of CW/CCW Coils.
Question: Do you know why CW/CCW is important?
   Chris Sykes
       hyiq.org
                        " Do you know why CW/CCW is important?
                                                         I,OCWL,
do not know what he, alias Utopia Now, shall know(s),Chris Sykes, but I will 'estimate' because :
                                credere ? are you believing ?
                                scire ?     are you knowing ?
                                audere ? non:audire  are you evaluating ? not: are you hearing ?
                                decidere ! you are deciding ! n-/ever ?
                                     It is important: gemeos,G-Mini,Zwilling? Siam/Thailand
                                               Siamesische Zwillinge : "eternal" Partner (if not cutted by me'docs ;) )
"Die schneidigen von Zwilling - Zwilling doppelt gut." but do not call me,never,"mother fucker"
                   Geht mir messerscharf durch den Koerper !
                            Mogs net !(baju-waric,capitale Monaco/Munich/Muenchen: I do not like it !)
