0 Members and 120 Guests are viewing this topic.
l0stf0x
Well.... I forgot to do some testings on this setup with the coils position and to test other type of size of ferrite... today I will complete them and I ll post the final circuit and details.
For now this is a fast video
https://youtu.be/uHBfBQXWun4
and one closer look at the transformer video.
https://youtu.be/h37aUqobKUc
Yesterday I had slightly better results but anyway..
voltage with load 7.58v
voltage without load 7.54v
current with load 0.11A
current without 0.19A
to be continued later today..
              http://overunity.com/10773/physicsprof-steven-e-jones-circuit-shows-8x-overunity/msg289287/#msg289287
                                                              answer 141 and 144 related :
                Partnered- hot and cold energy-output coils by hot/cold energy input :
                                                             ac-celerated                                 de-celerated
                                  you are experimenting,they did also experimented and publicated "results":
                                                            worth,to think about their "results" ?
                                      http://www.inpama.com/index.php?content=invention&id=733
                                      https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021121&CC=US&NR=2002171299A1&KC=A1#
                                      https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920507&CC=DE&NR=4035445A1&KC=A1#
                    you are in search for the "ambient energy transforming superconductive circuit" ,here you have to understand
                    the thermodynamic rules and orders (see : IBM work ,Bednarz Physics-Nobel-Award)
                   see the work from Adolf Zielinski and read also these:
                   German
                   https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=4&adjacent=true&locale=en_EP&FT=D&date=20000906&CC=EP&NR=1033807A1&KC=A1#
                   2English translated
                   http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=EP&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=1033807&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
                  cited documents:
                  https://worldwide.espacenet.com/publicationDetails/citedDocuments?CC=EP&NR=1033807A1&KC=A1&FT=D&ND=4&date=20000906&DB=EPODOC&locale=en_EP
                 Can "power amplifying" be so easy ?
                 https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=5&adjacent=true&locale=en_EP&FT=D&date=19981126&CC=DE&NR=29812556U1&KC=U1#
                https://www.google.pt/search?q=schwei%C3%9Ftransformator&client=firefox-b-ab&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjAvPvtnrzQAhXMPxQKHb98CmwQsAQIKQ&biw=1366&bih=667
( META C work-out could explain the effect https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=META+C&IN=&CPC=&IC=&Submit=Search
f.e. : https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20090227&CC=MY&NR=137586A&KC=A# )
                and  about reply 7559 : P.S:               One must ask why the Coil Orientation is so important!
                                                    In God we trust,but in this :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=20031204&CC=US&NR=2003222512A1&KC=A1#
                                                       also ?  ::)   Magnetic earth lines !
        As flying object :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=20040101&CC=US&NR=2004000251A1&KC=A1#
Also important: the winding(-s) orientation ! ccw or cw,vertical or horizontal,....... .
and not to misunderstand:    "physical" coils turns and "virtual" coil"Ampere"turns/windings
l0stf0x
Ok I had no better results yet.. so this is the circuit if you use the primaries (secondaries of normal use)next to each other.. using the small c core ferite.
If you flip the pairs of coils and you use the secondaries next to each other then you need a straight ferite block to get the same effect.
both ferites are found in the same component.. its an hf transformer for lcd back light used in laptops. (photos)
@ Chris: What you think of Don Smith generator? Is it a legit or a hoax and if its legit (I think it is) why we don't try it? :)
l0stf0x
I wanted to place a ferite as a block between the secondaries (imagine the coils flipped) in the drawing.. But it needs work to cut the laminations :) maybe I ll do it later.
EMJunkie
As always, nice work Lostfox!!!
Sorry I have not replied earlier! Been busy, World domination is a big job - Hahaha Just kidding.
Do you know why the Input current goes down under load? I think this is a real important point to understand and see why this works as it does.
   Chris Sykes
       hyiq.org
